Magneto Switch ?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List
Jimz
PostPosted: Tue May 08, 2012 5:42 am    Post subject: Magneto Switch ? Reply with quote
I have a 0-200 Continental engine in my Kitfox with Slick 4301 magnetos. I’m using a key start switch just like a Cessna 150 installation. My question is on the switch jumper. Some references say with dual impulse couplings one needs a jumper across terminal 1, others say not to use it. What have others done? Thanks Jim jezim(at)pro-ns.net (jezim(at)pro-ns.net)
- The Matronics Continental-List Email Forum -
http://www.matronics.com/Navigator?Continental-List
BARRY CHECK 6
PostPosted: Tue May 08, 2012 6:27 am    Post subject: Magneto Switch ? Reply with quote
Jim:
If you have DUAL Impulse coupling Mags then you DO NOT use the jumper.
BUT!  I would suggest: Use a separate Push Start for the switch just like Grumman's have.  The Mag Switch would be Left - Right & BOTH ... You would start on BOTH and and use the separate Push Button and you eliminate a AD issue... Yes, I know experimental, no AD but the problem still exists with the switch AND it gives you options if the switch should fail.
Barry
On Tue, May 8, 2012 at 9:42 AM, Jim & Elaine <jezim(at)pro-ns.net (jezim(at)pro-ns.net)> wrote:
[quote] I have a 0-200 Continental engine in my Kitfox with Slick 4301 magnetos. I’m using a key start switch just like a Cessna 150 installation. My question is on the switch jumper. Some references say with dual impulse couplings one needs a jumper across terminal 1, others say not to use it. What have others done? Thanks  Jim jezim(at)pro-ns.net (jezim(at)pro-ns.net)
st" target="_blank">http://www.matronics.com/Navigator?Continental-List
tp://forums.matronics.com
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List All times are GMT - 8 Hours
You cannot download files in this forum
