O200 Vacuum Pump cover
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List
Tommy Walker
PostPosted: Tue May 08, 2012 8:57 am    Post subject: O200 Vacuum Pump cover Reply with quote
I have an O200 with a vacuum pump. I don't plan to use any vacuum gauges so I want to take it off to save weight. Is there a plate or cover that I could get to seal off the engine. Also are there any gears or whatever that need to be removed when the pump is taken off?
Any help appreciated.
Tommy Walker in Alabama
Building - Kitfox SS w/O200
- The Matronics Continental-List Email Forum -
http://www.matronics.com/Navigator?Continental-List
Tommy Walker
N25A - Anniston, AL
BARRY CHECK 6
PostPosted: Tue May 08, 2012 12:30 pm    Post subject: O200 Vacuum Pump cover Reply with quote
Tom:
Yes, there is an OFFICIAL plate but since you are experminental you could make your own.  I would use 0.125" aluminum 6061 or 7075 with a gasket.  And since you are sealing it almost permanently use a slight smear of Hi Temp RTV.
NO - There aren't any gears to remove.
Barry
On Tue, May 8, 2012 at 12:57 PM, Tommy Walker <twalker(at)cableone.net (twalker(at)cableone.net)> wrote:
[quote]--> Continental-List message posted by: "Tommy Walker" <twalker(at)cableone.net (twalker(at)cableone.net)>
Tommy Walker
N8701  -  Anniston, AL
http://forums.matronics.com/viewtopic.php?p=372635#372635
List" target="_blank">http://www.matronics.com/Navigator?Continental-List
le, List Admin.
Tommy Walker
PostPosted: Wed May 09, 2012 4:57 am    Post subject: O200 Vacuum Pump cover Reply with quote
Thanks Barry.  I got lots of 0.125 and will fabricate me up one of the plates.
On Tue, May 8, 2012 at 3:29 PM, FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)> wrote:
[quote]Tom:
Barry
Tommy Walker
le, List Admin.
Tommy Walker
N25A - Anniston, AL
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List All times are GMT - 8 Hours
You cannot download files in this forum
