Help with Wiring
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lom-List
mjpienaar(at)shaw.ca
PostPosted: Mon May 28, 2012 6:44 pm    Post subject: Help with Wiring Reply with quote
Hi All,
I found a used "Slick Start" unit on ebay that came without instructions.
Does anybody have a wiring diagram that I could use?
Mike
- The Matronics Lom-List Email Forum -
http://www.matronics.com/Navigator?Lom-List
sbeaver(at)columbus.rr.co
PostPosted: Tue May 29, 2012 3:48 am    Post subject: Help with Wiring Reply with quote
You will find a diagram here: http://motorstarna.com/m14p-service-bulletins/57
Connect the ground pin to ground, the power pin to your starter solenoid so that it receives power when the starter is energized, and connect pin one to you left P-lead (in addition to the existing p-lead to mag switch wire. That remains unchanged)
Steve
From: Mike Pienaar <mjpienaar(at)shaw.ca (mjpienaar(at)shaw.ca)>
Reply-To: <lom-list(at)matronics.com (lom-list(at)matronics.com)>
Date: Monday, May 28, 2012 10:43 PM
Subject: Help with Wiring
Hi All,
Mike
com
ronics.com/contribution
PostPosted: Tue May 29, 2012 7:43 am    Post subject: Help with Wiring Reply with quote
Thanks for the quick reply, appreciate it
Mike
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lom-List All times are GMT - 8 Hours
