Pitot Tube Help
JLuckey(at)pacbell.net
PostPosted: Tue Jun 12, 2012 7:48 am    Post subject: Pitot Tube Help Reply with quote
Off topic! (well it is electrically heated;) Looking to capitalize on the Aerolectric Brain Trust to find an old pitot tube expert…
I have a pitot tube, Aero Instrument PH504, (AN 5811-1), which is looks like a typical C-172 pitot tube (you know, “L” shaped with about a 4 in tube attached to an airfoil cross-section vertical piece. When mounted under the wing on a C-172 the tube part would be closest to the ground.)
However this one is designed for INVERTED mounting, apparently designed to be mounted to a top surface of an airframe (where the tube part would be furthest from the ground.)
I’m pretty sure that the air doesn’t care which way the thing is mounted, as long as the tube is parallel to the air stream. So my guess is that the Inverted model has drain holes in different places.
Questions:
  1. does drain hole position REALLY matter?
  2. Multiple Choice: What will happen in flight if this device is mounted the standard way (not inverted) and it picks-up a little moisture?
    1. water in pitot lines
    2. inaccurate airspeed indication
    3. the end of life as we know it
    4. smoking crater
TIA,
Jeff Luckey
berkut13(at)berkut13.com
PostPosted: Tue Jun 12, 2012 8:05 am    Post subject: Pitot Tube Help Reply with quote
Are you sure that hole is a drain and not a static port?
Sent: Tuesday, June 12, 2012 10:46 AM
Subject: Pitot Tube Help
Questions:
    4. smoking crater
TIA,
Jeff Luckey
PostPosted: Tue Jun 12, 2012 8:28 am    Post subject: Pitot Tube Help Reply with quote
Yes, drawing that came with the unit indicates Drain Hole
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of berkut13(at)berkut13.com
Sent: Tuesday, June 12, 2012 09:03
Subject: Re: AeroElectric-List: Pitot Tube Help
Questions:
    4. smoking crater
TIA,
Jeff Luckey
href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c
Checked by AVG - www.avg.com
06/12/12 [quote][b]
PostPosted: Tue Jun 12, 2012 1:41 pm    Post subject: Pitot Tube Help Reply with quote
I have a pitot tube, Aero Instrument PH504, (AN 5811-1), which is looks like a typical C-172 pitot tube (you know, L shaped with about a 4 in tube attached to an airfoil cross-section vertical piece. When mounted under the wing on a C-172 the tube part would be closest to the ground.)
Im pretty sure that the air doesnt care which way the thing is mounted, as long as the tube is parallel to the air stream. So my guess is that the Inverted model has drain holes in different places.
Questions:
  • Multiple Choice: What will happen in flight if this device is mounted the standard way (not inverted) and it picks-up a little moisture?
  • water in pitot lines
  • inaccurate airspeed indication
  • the end of life as we know it
  • smoking crater
A modern pitot tube is a complex study in aerodynamics, pneumatics, thermal dynamics and manufacturing. Contemporary design goals for a 'qualified' pitot tube calls for testing in an icing tunnel that is supposed to be sort of a worst case icing condition.
http://tinyurl.com/7pmnqta
[img]cid:.0[/img]
The idea is to melt any ice accumulation and provide a place for the moisture to go besides into the pitot-static plumbing. At the same time, many airplanes are fitted with accumulators at the system's low-spot that include a drain for removing any water.
Some years ago at HBC, we had a series of incidents involving loss of pitot data on both sides at the same time at altitude with no visible moisture (clouds or ice crystals). Both systems recovered before the airplane landed and draining the accumulators produced no observable moisture.
The pitot tubes installed were grand-fathered over from earlier installations and not 'qualified' to the latest and greatest de-icing specs. In fact, the tubes were originally installed pointed up at about 45 degree angle and had been moved to the bottom pointed downward thus placing the drain hole in the wrong clocking.
New, latest and greatest tubes were installed. I'm not aware of any recurring incidents . . . need to make some phone calls. I'm a bit skeptical. I did some flight tests on the original tubes to measure internal and temperatures. The areas all over the tube remained well above freezing (LT1, LT3, LT4 curves
in http://tinyurl.com/74yr5q8 )
The idea that there was frozen blockage of passages inside the tube didn't compute. So even if water did run down into the plumbing, where did it come from? Thawed ice crystals? Your guess is as good as mine. In any case, position of the drain hole was certainly not a high order concern. What I did come to understand was that unless your heated pitot tube is mounted to a machine qualified for flight into known icing, the ability to heat the tube is of limited usefulness. Once the tube is overwhelmed the flight characteristics (airfoil shapes) combined with added weight of ice make sort of pollutes the value of knowing indicated airspeed. The recommended process being to get to warmer altitudes without without changing anything that would move you closer to the low-speed corner of a flight envelope that is no longer defined.
What you have is probably a fine device for use outside of icing conditions. Inside icing conditions becomes a toss-up as to whether the flight qualities airplane or the instrumentation get overwhelmed first.
Wire that heater up if it makes you feel any better but know that having good IAS numbers is only part of the equation. Got a real good lesson during my only in-flight instrument approach in icing conditions. In this case, my instructor was sitting there calmly waiting for me to figure it out all the way down to the flare after having kept all the needles centered up for over 15 minutes in the clouds.
The airplane fell out of the air and muffed what was supposed to be a good "by the numbers" landing . . . numbers that no longer represented the shape of the wing. Bottom line is that ice presents worries that can be a lot more hazardous than IAS numbers.
 Filesize:  176.58 KB
 Viewed:  11790 Time(s)
BobsV35B(at)aol.com
PostPosted: Tue Jun 12, 2012 2:10 pm    Post subject: Pitot Tube Help Reply with quote
Good Afternoon Bob,
We have had this same discussion before and I think we agreed to disagree, but since you presented your side of the discussion, mind if I add mine?
Ice is where you find it.
Icing forecasts are not real reliable and if you never fly in conditions where ice is a possibility, you deprive yourself of a lot of flexibility.
Some say that the way to handle ice is to avoid it.
My thought is that the way to handle ice is to keep a good way handy to get out of the ice.
That has worked well for me over the last 62 years since I earned my Instrument rating.
I do agree with you that we can fly adequately and safely without an airspeed indicator, but faster airplanes do make speed control much easier if we have a good airspeed indication.
In my book, a couple hundred bucks spent to get a heated pitot tube is money well spent.
Just this old guy's opinion!<G>
Happy Skies,
Old Bob
Downers Grove Illinois
Stearman N3977A
Beech V35B N20318
In a message dated 6/12/2012 4:44:10 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
Subject: AeroElectric-List: Pitot Tube Help
Questions:
  • smoking crater
 Filesize:  176.58 KB
 Viewed:  11787 Time(s)
Eric M. Jones
PostPosted: Wed Jun 13, 2012 4:45 am    Post subject: Re: Pitot Tube Help Reply with quote
My 2 cents:
I have kept the attached drawing of a pitot tube around to remind me that there are lots of ways to go, and lots that is known that I don't know.
pitotc46.pdf
Download
 Filename:  pitotc46.pdf
 Filesize:  35.95 KB
 Downloaded:  750 Time(s)
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
BobsV35B(at)aol.com
PostPosted: Wed Jun 13, 2012 5:34 am    Post subject: Pitot Tube Help Reply with quote
Good Morning Eric,
Sure looks busy!
Happy skies,
Old Bob
In a message dated 6/13/2012 7:49:00 A.M. Central Daylight Time, emjones(at)charter.net writes:
--> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net>
My 2 cents:
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
http://forums.matronics.com/viewtopic.php?p=375506#375506
http://forums.matronics.com//files/pitotc46_198.pdf
deej(at)deej.net
PostPosted: Wed Jun 13, 2012 6:23 am    Post subject: Pitot Tube Help Reply with quote
On 6/13/2012 9:32 AM, BobsV35B(at)aol.com (BobsV35B(at)aol.com) wrote:
Sure looks busy!
Yeah, I'm having pitot envy. The pitot tube on my plane is literally just an aluminum tube bent into the wind... Smile
-Dj
PostPosted: Wed Jun 13, 2012 10:33 am    Post subject: Pitot Tube Help Reply with quote
One data point for those who care: I connected the heater to a 12V
power supply and found that after about a minute the current was
about 2.5 amps (at) 12.8 volts and the tube was hot enough to sizzle
spit, literally. The tube is rated for 24V.
Which brings up another set of design goals for
heated pitot installation. How much energy and
under what conditions are needed for perfomance
to design goals. While doing those studies for
HBC I crafted this paper on heater temperature
coefficient of resistance and thermal resistance
from heater to tube.
http://tinyurl.com/7778mm5
When operated in insulated, still air, the 13v pitot
tube temperature rose to over 100C with less than
2 volts applied power. When operated at rated voltage
in a stirred ice bath, the surface of the tube was
of course at 0C but the internal heater was running
at about 270 degrees C.
Modern tubes don't have so large a differential. Another
important revelation was the cold start resistance of the
pitot tube. Just coming up from 0C, the tube wanted
30+ amps of inrush that persisted quite awhile. It took
about 30 seconds for the current to stabilize at the
expected 16 amps of steady state draw.
During one set of flight tests, we installed thermocouples
http://tinyurl.com/6o5hpdk
and produced this data set
http://tinyurl.com/7ougkfu
Note that at 40K feet, -50C OAT and IAS about 200 kts,
the hot spot on the tube (Ta) was 100C or better. That
cold air blasting the tube at high velocity doesn't have
very good cooling qualities at such low ambient pressures.
Eric M. Jones
PostPosted: Thu Jun 14, 2012 10:46 am    Post subject: Re: Pitot Tube Help Reply with quote
I was always of the opinion that a heated pitot tube would be very useful for home-built aircraft even it it wasn't certified for known-icing-conditions at 30,000 feet and jet plane speeds. Furthermore the reason pitot tubes are heated with such high power is because they are made of material that conducts heat rapidly. A strange design to be sure.
For those interested in my old Thermostatic Pitot Tube see:
http://www.periheliondesign.com/downloads/thermopitot.pdf
I test it outside my workshop every time an ice-storm dumps on New England...and it performs flawlessly. Everything else is iced over while it is not. No flight tests yet.
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
gerry.vandyk(at)shaw.ca
PostPosted: Thu Jun 14, 2012 11:23 am    Post subject: Pitot Tube Help Reply with quote
Here in Canada the equipment regs for IFR flight require the pitot be heated. Is this not the case in the US?
Gerry
jay(at)horriblehyde.com
PostPosted: Thu Jun 14, 2012 9:05 pm    Post subject: Pitot Tube Help Reply with quote
Looks great Eric! Very interesting page...
Jay
millner(at)me.com
PostPosted: Mon Jun 18, 2012 8:36 am    Post subject: Pitot Tube Help Reply with quote
Not required on the US.
Paul
Please note my new email address!
millner(at)me.com
