40 MPH Stall
Goto page Previous  1, 2
ceengland(at)bellsouth.ne
PostPosted: Fri Jan 13, 2006 1:41 pm    Post subject: 40 MPH Stall Reply with quote
Possum wrote:
Can you provide a link to the $35 hall asi product?
http://www.hallwindmeter.com/wind.php
Ok, can you tell I don't fly UL's a lot? Smile
I read the note & got it in my head that you were talking about an
electronic no moving parts pressure sensor type asi.
Thanks...
Lloyd McFarlane
PostPosted: Fri Jan 13, 2006 3:07 pm    Post subject: 40 mph stall Reply with quote
My Firestar II weighs 415lbs & I weigh 200. I stall at approx. 42mph.
Lloyd McFarlane
Fullerton, CA
Larry Cottrell
PostPosted: Fri Jan 13, 2006 3:46 pm    Post subject: Re: 40 MPH Stall Reply with quote
I originally sent this on the 12th and it didn't show up on the BB. Somehow
or other all that showed up was that I had sent a message, not the body of
the message. So I will try again.
> Ralph,
> I purchased my Firestar in 1997. It weighed 278 lbs. I weighed 230, It
> stalled at 46 MPH. I did a few changes that involved more weight (360) and
> the stall went up a bit but not more than 2 MPH. Then I installed VG's to
> each full rib and the stall dropped to 36 MPH. This last year I put them
> on the false ribs as well and the stall dropped to 26 MPH. I also need to
> tell you that my runway is at 4630 ft above sea level. I believe that
> Possums bought his from Landshorter.com, and paid about $100.00. I made
> mine from plans developed by Howard Shackleford. I have some made from
> alum, and some made from lexan. I believe that I like those the best. I do
> believe that it will cost you about 2 mph on your cruise, but that is a
> choice that I am happy to live with. I know how you feel about the stall
> speed since that was one of the factors that decided me on a Kolb, since
> most of the places that I would be landing would be other than on a
> runway. I too wondered why mine stalled so fast. So I believe that the
> speed you are experiencing is a bit more realistic.
I noticed that the site selling the Halls had some VG'S that look just
like the ones that Mr Shackleford drew up, only theirs was 240.00? for a
kit.
> Larry, Oregon
flht99reh(at)netzero.net
PostPosted: Fri Jan 13, 2006 7:47 pm    Post subject: 40 MPH Stall Reply with quote
Larry Thanks. I have seen the devices you have installed and have read the
views on this site regarding them. I will at some time, no doubt add them.
And I appreciate everyone's assistance. Have you looked at the e-mail post
regarding Stall and GPS? It gives the last trips numbers.
PostPosted: Fri Jan 13, 2006 8:02 pm    Post subject: 40 MPH Stall Reply with quote
Thanks Larry, What is the placement and spacing as well as the number per
wing that you installed? And how did you determine the number and distance?
Would you be interested in making additional ones? And NO I am not a lawyer,
nor would I sue anyone if the didn't work! Also Larry, How did you get them
to adhere?
The other Ralph
Larry Cottrell
PostPosted: Fri Jan 13, 2006 9:34 pm    Post subject: Re: 40 MPH Stall Reply with quote
I attatched the first set at 11 inches back from the leading edge. These were on the full ribs. I then attatched the second set on the false ribs and I set those with the back of the VG's even with the front of the previous set. I have included the information that I received to make mine. I attatched them with double sided servo tape from a hobby store. It does well. If for some reason they don't come through let me know and I will send them to your email. If you use lexan (1/16 ) You can bend the lexan just as easy as alum, but being clear it is not necessary to paint them. The color shows right through making them almost invisible.
Larry
 Filesize:  215.29 KB
 Viewed:  593 Time(s)
 Filesize:  306.84 KB
 Viewed:  601 Time(s)
VG's and how to make them
 Filesize:  113 KB
 Viewed:  595 Time(s)
jdmurr(at)juno.com
PostPosted: Sat Jan 14, 2006 5:30 pm    Post subject: 40 mph stall Reply with quote
My Firestar Weighs 355 and I weigh 200. We stall at 35 mph IAS
Lloyd McFarlane
Fullerton, CA
--"LloydMcFarlane"lrmcf(at)ix.netcom.comwrote:
--Kolb-Listmessagepostedby:"LloydMcFarlane"lrmcf(at)ix.netcom.com
MyFirestarIIweighs415lbsIweigh200.Istallatapprox.42mph.
LloydMcFarlane
Fullerton,CA
Page 2 of 2
