RV4 ventilation
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List
smullins(at)drury.edu
PostPosted: Mon May 29, 2006 10:39 am    Post subject: RV4 ventilation Reply with quote
Hi Brian,
I live in Springfield MO, and it gets really hot here in the summer. I tried
adding a NACA vent on the left side of the cockpit, right below the
throttle/mixture controls. It DID NOT work so I subsequently patched the
cutout. Must be a low pressure area right above and behind the leading edge
of the wing at the root.
Good Luck. If you dicover something that works well, let me know.
PS. I have had good results with the autoshade film that you can get at any
auto supply. You can easily cut it to shape and put it on the inside of the
canopy above your head in the summer, and take it off in the winter. I does
help cut the amount of solar heating you get under the canopy.
Steven D. Mullins
Associate Professor of Economics
Co-director 06-07 Convocation Series: http://www.drury.edu/post911
"Preparing ethical leaders for the global business community"
The Breech School of Business Administration
Drury University
417.889.5609 (Home)
417.873.7299 (Office)
- The Matronics RV4-List Email Forum -
http://www.matronics.com/Navigator?RV4-List
SSampson.SLN21(at)london.
PostPosted: Mon May 29, 2006 10:42 am    Post subject: RV4 ventilation Reply with quote
Brian on the VANS airforce web site/ RV4 section/ Thread = heater there is a
posting by Kahuna that will interest you. I have purchased the same vents
for installation. This might get you there:
http://www.vansairforce.com/community/showthread.php?postid=51073#post51073
Good luck, Steve
#4478
UK
PS Most of the activity appears to have moved the that site now.
mbick(at)carolina.rr.com
PostPosted: Mon May 29, 2006 3:23 pm    Post subject: RV4 ventilation Reply with quote
I just put one of the Vans pop out vents in my RV 4 and it works great. I
would recommend doing so! It seals up pretty good too.
Mike
Warren.Moore(at)tidelands
PostPosted: Tue May 30, 2006 8:26 am    Post subject: RV4 ventilation Reply with quote
Brian, I put a naca vent (from Van's) on the right side of the fuse. as far
forward as possible and just under the cowl cheek. ran a scat tube to the
lower right side of the instrument panel to an alum. vent....it works just
ok. Also installed a naca vent on the underside of the the right wing,
(like on the RV8's) to a scat tube, to a large 3" vent mounted just forward
of the rear stick, for the rear passenger.....works great! also put a tee
in the rear vent scat tube and ran a 1-1/4 in scat tube to the front seat
(thur the wing spar where the plans show a routing for rear seat heat (I
have no rear seat heat). to a small vent mounted down low by the fuel
selector. When flying solo, I can reach back, close the rear seat vent and
open the front one full, just works great! Still get a lot of air in front
and back when both are open.
I working now on a way to hold my canopy open about 3 inches for
taxi....don't care how many vents you have, on ground its just hot under a
bubble canopy.
Warren Moore
rv4 n223wm, 35 hrs.
PostPosted: Tue May 30, 2006 11:46 am    Post subject: RV4 ventilation Reply with quote
Brian and all,
On your holding your canopy open 3 " while taxiing!!! I hope I haven't
committed some horrible sin, but I have been taxiing my RV 4 with the canopy
open for 4 years with no problems.
Steven D. Mullins
Drury University
417.889.5609 (Home)
smokyray(at)yahoo.com
PostPosted: Tue May 30, 2006 12:33 pm    Post subject: RV4 ventilation Reply with quote
Brian,
All of the previous suggestions work, I have one of each! Over the years I have tried everything including bypassing my heat muff and running baffle air into the cockpit. Works fine above 5K but hot down low. Here is what worked and improved what I had...
An aeronautical engineer looked at my airplane and told me the two lowest pressure and highest pressure areas, the canopy rail and right in front of the leading edge of the wing being very low. The bottom of the rear part of the cowl cheek, fuselage sides above the landing gear and under the wing, being very high. So, I installed and really like two of Larry Vettermans pop-out round vents, one right above the throttle quadrant and the other in front of the back seat on the fuselage 8" below the canopy rail. I also have three NACA scoops, one on the front lower left fuselage which like Warren's works well. I also installed two on the canopy rail before I knew better. One thing that helped both of them was placing VG's in front of them, 50% improvement in airflow. Hey, I live where it is hot year-round!
However, the absolute best modification was drilling holes around my baggage door bulkhead to allow the air to draft out the rear fuselage. "Sucking the air out" of the cockpit is not a new idea, look at Christen Eagles. They have reverse NACA scoops. Rear seat passengers tell me they can lay their hands over the holes and feel the suction at cruise speed.
The aft part of the canopy is very high pressure and a rear facing vent on the lower part of the back of the canopy fairing on one RV4 reported very good airflow into the cockpit. He said he got the idea off a T-18. He had a choke cable to open and close the small door.
Another simple fix to summer heat is to use the RV4's superior performance and fly above 5K if you go anywhere.
For some great ideas of the canopy taxi position hold-back devices, go to Doug Reeves website http://www.vansairforce.com/community/showthread.php?t=7769&page=1&pp=10
You will find alot of great pictures of canopy taxi positions installations (including mine)...
Good Luck!
RR
bubble canopy.
Warren Moore
rv4 n223wm, 35 hrs.
PostPosted: Tue May 30, 2006 12:35 pm    Post subject: RV4 ventilation Reply with quote
Again, Here are some great pics...
RR
Steve Mullins <smullins(at)drury.edu> wrote:
Brian and all,
Steven D. Mullins
Drury University
417.889.5609 (Home)
James Baldwin
PostPosted: Wed May 31, 2006 10:43 am    Post subject: RV4 ventilation Reply with quote
Brian -
Where did you order the vents from? Thx. JBB
Brian Vickers wrote:
Thanks for your response. Yesterday I ordered the Vetterman pop-out vents.
Like Larry the Cable TV Repairman says, "Time to get er' done!" Thanks
again. By the way, I just viewed that tree top video. That is a University
of Washington Husky emblem/logo on the back of his hat. I suspect he was
flying along one of the many rivers here in Washington. Interesting.
Sincerely, Brian Vickers
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List All times are GMT - 8 Hours
