Exhaust clamp seals
bwade154(at)yahoo.com
PostPosted: Thu Jul 12, 2012 2:33 pm    Post subject: Exhaust clamp seals Reply with quote
whats the current fix for exhaust leaks at the joints where the pipes come together.
Thanks Bill Wade
viperdoc(at)mindspring.co
PostPosted: Thu Jul 12, 2012 7:19 pm    Post subject: Exhaust clamp seals Reply with quote
Get a stainless steel exhaust clamp kit from M14P. Wrap the joint with 2 mm stainless steel cut with an tin snip to span the gap. Cut it long enough to wrap around the joint like you would wrap tape around a pipe. Then install the stainless clamps over the taped joint with your third hand.
Doc
Sent from my iPad
On Jul 12, 2012, at 5:27 PM, bill wade <bwade154(at)yahoo.com (bwade154(at)yahoo.com)> wrote:
[quote]whats the current fix for exhaust leaks at the joints where the pipes come together.
Thanks Bill Wade
Vic
PostPosted: Fri Jul 13, 2012 4:12 pm    Post subject: Re: Exhaust clamp seals Reply with quote
Hello,
just canĀ“t see how a sheet metal system could possibly provide a real "seal" over rough pipe joints. So we tried glass fiber wraps over one layer of the original inner sheet seals and tightened the whole set with the standard clamp on the top of it. This works well so far but expect the seal to settle in a few hours so check the clamps - as you do regularly all pipe joints to cyl. heads.
http://www.ebay.com/itm/EXHAUST-PIPE-HEADER-WRAP-2-X-20-WHITE-FIBERGLASS-CAR-MOTORCYCLE-/200790517169?pt=Motorcycles_Parts_Accessories&hash=item2ec00c25b1&vxp=mtr
Cheers
Vic
 Filesize:  447 KB
 Viewed:  5521 Time(s)
Snazpappy
PostPosted: Thu Mar 14, 2019 12:26 pm    Post subject: Re: Exhaust clamp seals Reply with quote
Any follow up on how this wrap of fiberglass heat shield worked? I am thinking of trying this.
Snaz
Vic
PostPosted: Thu Mar 14, 2019 6:21 pm    Post subject: Re: Exhaust clamp seals Reply with quote
We still keep this fiberglass seal, no better idea so far. But when you have to take off the exhaust you need a fresh length of fiber of course because a well used seal ages and disintegrates when undoing. But cheap enough and reasonably tight. Take care to fit one layer of stainless under the fiber for protecting it from fire.
Vic
