barrynorman(at)comcast.ne Guest
Posted: Mon Jul 16, 2012 5:53 am Post subject: Fuel tank leak |
I finally go the wings off the plane to take a closer look at the leaks. Before taking the end plate off the right tank, I put fuel in it while it was setting on some saw horses to see exactly were it was leaking from. It appears to be coming out at the top of the spar where the skin to the tank meets the spar. This kinda surprised me but was explained when I took the end plate off. It appears that the Jeffco fuel tank sealer released in a small spot on the fiberglass angle near the top of the wing. This must have started the leak. Jim's suggestion to build a fillet looks like it will fix this problem.
I noticed that the area in the tank where the flap return spring bracket comes through had cracked and the Jeffco, micro/epoxy mix built up around it and was falling apart. This means the spar was exposed to fuel in a half dollar sized area. I checked the bracket and it was tight and rigid and the area of the spar exposed to fuels seemed unaffected. It's still hard and appears normal. There appeared to be no leakage through to the other side where the spring attaches. BTW, these tanks were factory built by Skystar.
I noticed that the Jeffco is over $500 for a 3 gallon kit which is outrageous. They don't offer a smaller kit. There is another product being sold called Bill Hirsh gas tank sealer that is much cheaper and claims resistance to alcohol. Has anyone had experience with this product. Will it work with Jeffco?
Barry
| - The Matronics Pulsar-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
Posted: Mon Jul 16, 2012 5:55 am Post subject: Fuel tank leak |
I finally go the wings off the plane to take a closer look at the leaks. Before taking the end plate off the right tank, I put fuel in it while it was setting on some saw horses to see exactly were it was leaking from. It appears to be coming out at the top of the spar where the skin to the tank meets the spar. This kinda surprised me but was explained when I took the end plate off. It appears that the Jeffco fuel tank sealer released in a small spot on the fiberglass angle near the top of the wing. This must have started the leak. Jims suggestion to build a fillet looks like it will fix this problem.
I noticed that the area in the tank where the flap return spring bracket comes through had cracked and the Jeffco, micro/epoxy mix built up around it and was falling apart. This means the spar was exposed to fuel in a half dollar sized area. I checked the bracket and it was tight and rigid and the area of the spar exposed to fuels seemed unaffected. It's still hard and appears normal. BTW, these tanks were factory built by Skystar.
I noticed that the Jeffco is over $500 for a 3 gallon kit which is outrageous. There is another product being sold called Bill Hirsh gas tank sealer that is much cheaper and claims resistance to alcohol. Has anyone had experience with this product.
Barry
mortweaver(at)sbcglobal.n Guest
Posted: Mon Jul 16, 2012 6:37 am Post subject: Fuel tank leak |
You should never attempt to overlap Jeffco over a poly sulfide sealant. Jeffco is essentially inert when cured. There should be no problem with over coating Jeffco with a poly sulfide. The fuel tank end plate closure sealant is a typical example. I went from a poly sulfide wing tank sealant to Jeffco a few years back....an awful job scrubbing out the wing tanks with MEK (required about 12 gallons). The Jeffco wing tank sealant has held up well and was when I last checked used by Lancaire.
Dave Weaver
--- On Mon, 7/16/12, barrynorman(at)comcast.net <barrynorman(at)comcast.net> wrote:
Quote: |
From: barrynorman(at)comcast.net <barrynorman(at)comcast.net>
Subject: Fuel tank leak
To: "pulsar-list" <pulsar-list(at)matronics.com>
Date: Monday, July 16, 2012, 8:53 AM
#yiv490300858 p {margin:0;} I finally go the wings off the plane to take a closer look at the leaks. Before taking the end plate off the right tank, I put fuel in it while it was setting on some saw horses to see exactly were it was leaking from. It appears to be coming out at the top of the spar where the skin to the tank meets the spar. This kinda surprised me but was explained when I took the end plate off. It appears that the Jeffco fuel tank sealer released in a small spot on the fiberglass angle near the top of the wing. This must have started the leak. Jim's suggestion to build a fillet looks like it will fix this problem.
Barry
Quote: |
r-List
Quote: |
| [quote][b]
Posted: Mon Jul 16, 2012 7:09 am Post subject: Fuel tank leak |
The tanks are sealed with Jeffco from the factory. From what I read the Bill Hirsh stuff stays flexible whereas I've seen the Jeffco crack where flexed.
Barry
To: pulsar-list(at)matronics.com
Sent: Monday, July 16, 2012 10:37:09 AM
Subject: Re: Fuel tank leak
Dave Weaver
Barry
Quote: |
3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D r-List
3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
| [quote]
sonja.englert(at)juno.com Guest
Posted: Mon Jul 16, 2012 7:28 am Post subject: Fuel tank leak |
Hello Everyone,
For those of you who are also interested in motorgliders, I have posted another video of the motorglider fly-in in Minden, NV I attended a few days ago. Here is the link:
http://youtu.be/1Er7l602ft0
Sonja
____________________________________________________________
Woman is 57 But Looks 27
Mom publishes simple facelift trick that angered doctors...
http://thirdpartyoffers.juno.com/TGL3131/500432fb64b9232fb0550st53duc
Posted: Mon Jul 16, 2012 9:21 am Post subject: Fuel tank leak |
Jeffco, although rated for corrosive chemicals such as acids, has a very critical mixing ratio requirement. Jeffco carries a warning with regard to following mixing instructions as it becomes less flexible with the use of more hardener. It requires two coats as gasses released during cure process will cause bubbles and leave pin holes in the curred coating. Jeffco is very easy to apply to large areas as it has superior wicking characteristic compared to a poly sulfide sealant. My header tank was a retrofit following completion of kit construction and was sealed with PR - 1750. PR - 1750 Poly Sulfide has good flexibility and is rated for alcohol. It is also a good close-out plate sealant.
Dave Weaver
Date: Monday, July 16, 2012, 10:08 AM
#yiv99009826 p {margin:0;} The tanks are sealed with Jeffco from the factory. From what I read the Bill Hirsh stuff stays flexible whereas I've seen the Jeffco crack where flexed.
Barry
Dave Weaver
#yiv99009826 p {margin:0;} I finally go the wings off the plane to take a closer look at the leaks. Before taking the end plate off the right tank, I put fuel in it while it was setting on some saw horses to see exactly were it was leaking from. It appears to be coming out at the top of the spar where the skin to the tank meets the spar. This kinda surprised me but was explained when I took the end plate off. It appears that the Jeffco fuel tank sealer released in a small spot on the fiberglass angle near the top of the wing. This must have started the leak. Jim's suggestion to build a fillet looks like it will fix this problem.
Barry
Quote: |
r-List
Quote: |
| [quote][b]
