Oil Filter Removal Tool for O-320
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List
genie(at)swissmail.org
PostPosted: Sun Jul 22, 2012 1:18 am    Post subject: Oil Filter Removal Tool for O-320 Reply with quote
Which is your favourite tool for the removal of an oil filter? I have
got an O-320 and a Kelly Aerospace ES48108-1 filter attached to the firewall.
Thanks.
George Nielsen
Vans RV-6 PH-XGN
The Hague, the Netherlands
- The Matronics LycomingEngines-List Email Forum -
http://www.matronics.com/Navigator?LycomingEngines-List
BARRY CHECK 6
PostPosted: Sun Jul 22, 2012 5:50 am    Post subject: Oil Filter Removal Tool for O-320 Reply with quote
George:
The filter has a (I believe) a 1" hex-nut on the end. So the easiest tool to use is a 1"   Combination wrench.  REMEMBER you do NOT kill the filter with tons of torque.  Most filters have the required torque written right on them.  It is basically Hand Tight and them 1/2 a turn more.
Barry
RV6 also  Smile
On Sun, Jul 22, 2012 at 5:12 AM, George Nielsen <genie(at)swissmail.org (genie(at)swissmail.org)> wrote:
[quote]--> LycomingEngines-List message posted by: George Nielsen <genie(at)swissmail.org (genie(at)swissmail.org)>
Which is your favourite tool for the removal of an oil filter? I have got an O-320 and a Kelly Aerospace ES48108-1 filter attached to the firewall.
Thanks.
George Nielsen
Vans RV-6 PH-XGN
nes-List" target="_blank">http://www.matronics.com/Navigator?LycomingEngines-List
http://forums.matronics.com
le, List Admin.
teamgrumman(at)yahoo.com
PostPosted: Sun Jul 22, 2012 9:07 am    Post subject: Oil Filter Removal Tool for O-320 Reply with quote
I've measured a dozen or so oil filters that I've installed. 70-80 inch-lbs is plenty of torque. The 192 to 216 inch-lbs as marked on the filter (16-18 ft-lbs) is ridiculous over kill. It shouldn't take a gorilla to remove the filter.
To: lycomingengines-list(at)matronics.com
Sent: Sunday, July 22, 2012 6:47 AM
Subject: Re: Oil Filter Removal Tool for O-320
George:
Barry
RV6 also Smile
Thanks.
George Nielsen
Vans RV-6 PH-XGN
le, List Admin.
http://www.matronics.com/follow" target="_blank" href="http://forums.matronics.com/">http://foru=====
BARRY CHECK 6
PostPosted: Sun Jul 22, 2012 1:57 pm    Post subject: Oil Filter Removal Tool for O-320 Reply with quote
Gary:
I agree with you 100%.
And the main reasons are:
1 - The male and female threads are Oil Coated - And they better be.
2 - The Rubber gasket is oil coat - And it better be.
3 - Even if you use a torque wrench on the oil filter to the required torque the holding force because of the OIL will be much higher then truly required.
QUESTION:  I never checked - - Does the printed torque say Wet or Dry?
If not stated then it means DRY and if DRY it is incorrect to install the rubber gasket that way.
HAND TIGHT PLUS 1/2 A TURN MORE.
Never had a oil filter leak.
Never hand a oil filter come loose.
NEVER - NEVER had to use a breaker bar or a screwdriver through a oil filter to remove it.
AND Don't forget you should be using Safety Wire.
Barry
On Sun, Jul 22, 2012 at 1:04 PM, Gary Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
[quote] I've measured a dozen or so oil filters that I've installed.  70-80 inch-lbs is plenty of torque.  The 192 to 216 inch-lbs as marked on the filter (16-18 ft-lbs) is ridiculous over kill.  It shouldn't take a gorilla to remove the filter.
From: FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)>
To: lycomingengines-list(at)matronics.com (lycomingengines-list(at)matronics.com)
George:
Barry
RV6 also  Smile
Thanks.
George Nielsen
Vans RV-6 PH-XGN
le, List Admin.
PostPosted: Mon Jul 23, 2012 12:09 am    Post subject: Oil Filter Removal Tool for O-320 Reply with quote
It says to use Dow 4
Gary
Sent from my iPad
On Jul 22, 2012, at 2:54 PM, FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)> wrote:
[quote]Gary:
Barry
George:
Barry
RV6 also Smile
Thanks.
George Nielsen
Vans RV-6 PH-XGN
le, List Admin.
href="http://www.matronics.com/Navigator?LycomingEngines-List">http://www.matronics.com/Navigator?LycomingEngines-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List All times are GMT - 8 Hours
