Posted: Wed Aug 01, 2012 2:23 pm Post subject: PM Alternator filter Capacitor - best practices |
At 04:57 PM 8/1/2012, you wrote:
| Quote: | What would be considered best practice for installation of the large electrolytic capacitor used to filter the output of a PM alternator:
Mount it on the hot side of the firewall and protect the occupants
Mount it on the cool side of the firewall and protect the capacitor
Would appreciate any speculations, -john-
It's utility is limited. See in particular,
the second page of
http://tinyurl.com/cz7ekrf
even with no capacitor, the noises are
well under Mil-STD-704 limits for DC
power systems. So mounting it 'cool'
probably bodes best for service life
and has little effect on system
performance.
Bob . . . [quote][b]
jloram
Joined: 07 Nov 2009 Posts: 54 Location: United States
Posted: Wed Aug 01, 2012 3:47 pm Post subject: PM Alternator filter Capacitor - best practices |
Hmmmm... so why do we use this cap?
-john-
[quote] From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Wednesday, August 01, 2012 3:23 PM
Subject: Re: PM Alternator filter Capacitor - best practices
the second page of
performance.
Bob . . . | Quote: |
| [b]
Posted: Thu Aug 02, 2012 4:28 am Post subject: PM Alternator filter Capacitor - best practices |
At 10:18 PM 8/1/2012, you wrote:
So we're not trying to control the bandwidth of the regulator loop
with the cap? Does the battery do that? Guess I don't really know
what the frequency response of a lead-acid battery is. Probably
dependent on the state of charge and the condition of the battery.
And the load varies all over the place, both real and imaginary
components.... What would it look like with and without the cap if
the battery were out of the loop? ... Scary!
http://tinyurl.com/bqa6q9p
Finely tuned loop dynamics with these regulators is wishful
thinking. Here's an exemplar schematic for a PM regulator:
http://tinyurl.com/bwomjjz
I split out the two functions (regulation and
warning light)
http://tinyurl.com/c8usyw2
http://tinyurl.com/c6doa97
As you can see in the v-reg schematic,
there are no reactive components that
would shape closed-loop response. A battery
is a very poor 'filter' . . . it delivers
energy at 12.5 and below . . . accepts
energy at 13.8 and above. That's about
1.3 volts of span where the battery is
dynamically 'unhooked'.
It stands to reason that the capacitor
would have the greatest effect when the
alternator set point was too low (under
14.5) and the system was lightly loaded.
I'm running 3 phase (old Jab 3300).
Interesting. I think your regulator is
still quite similar . . . it just adds
another diode/scr pair.
Once I get this thing fired up I'll run some tests and let you know
what happens...
I have a fast switching, dynamic load bank
I built for tests at HBC some years back.
It would be interesting to use it along
with a data acquisition system on the
test bench to explore the closed loop
response of these systems.
Just thinking out loud, -john-
p.s. ran into a message the other day that you wrote back in 2007.
Said you worked for H.L Yoh as a civilian instructor in the early
60's... Same here! At the Naval ETA school on Treasure Island. Wasn't
that fun. I learned more electronics in six months instructing those
kids than four years of collage!
You got that right! I was teaching in the
top 4 weeks of a 26 week school at Great
Lakes. I went to work on a Friday and they
handed me a syllabus for my first section
of students along with a copy of "the bible",
Termnan's Electrical Engineering Handbook
http://tinyurl.com/cbvvjx9
and said, "you get your first class of 20
next Monday." As long as I stayed a day ahead
of the class . . . things went well . . .
and yes, a lot of fun. After four or
so passes through the class materials and
figuring out a half dozen ways to explain each
concept, it sorta creeps into your DNA. There's
no better way to learn something than to
be chartered to teach it.
Do you have access to a fast data acquisition
system that you could hook to your bus for
some hard data gathering?
I've used cousins to this critter . . .
http://tinyurl.com/3jtrxx4
on several tasks at HBC with great results.
Being able to jump on an airplane and get
hard data in flight without having to involve
a dozen folks from the instrumentation lab
was a powerful tool.
You might consider getting one of these
and use it to graph some of the performance
qualities of your system. It would be a great
augmentation of my ripple studies.
warning light)
what happens...
Tundra10
Joined: 14 Jun 2010 Posts: 102 Location: Scarborough, Ontario
Posted: Thu Aug 02, 2012 7:55 am Post subject: Re: PM Alternator filter Capacitor - best practices |
So should the capacitor and 1K resistor be deleted from Z13/8 ?
Note 20 indicates the purpose of the capacitor is to smooth the voltage if the battery is offline. However, there is no intentional way of disconnecting the battery, and there are very few failures that could result in the battery being disconnected while the SD-8 still remains connected to the battery bus.
In Z13/8 the SD-8 is only turned on in the event of a main alternator failure. Maybe in this circumstance, a little noise in the audio is not significant to the completion of the flight (assuming the capacitor actually helps in a given installation).
Jeff Page
Dream Aircraft Tundra #10
jloram
Posted: Thu Aug 02, 2012 3:08 pm Post subject: PM Alternator filter Capacitor - best practices |
Thank you for the schematics. Most instructive!
early 60's... Same here! At the Naval ETA school on Treasure
Island. Wasn't that fun. I learned more electronics in six
months instructing those kids than four years of collage!
And thank you for Villard's Memoir. I loved reading every bit of it!
Like every self-respecting EE I have kept my copy of Terman.
[img]cid:229104122(at)02082012-1950[/img]
And in every other class you'd get one 'ringer'. A kid fresh out of engineering school who would nail you to the chalk board at the slightest slip-up!!! You either got those guys on your side right away or you were in for some tough sledding!
| Quote: | Do you have access to a fast data acquisition
[img]cid:229104122(at)02082012-1957[/img] I have a couple of these first generation DI-148Us.
It will run at 11 KHz sampling rate on one channel.
Tell me more about your dynamic load bank. Sounds like just the ticket.
| Quote: | ...
I'd be happy to contribute!
I'm probably a month away from first start and another month coming down off the high!!, -john-
65.53 KB |
8897 Time(s) |
84.81 KB |
8897 Time(s) |
