Flap breaker popping
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
t.j.vanduin(at)gmail.com
PostPosted: Sat Aug 04, 2012 1:13 pm    Post subject: Flap breaker popping Reply with quote
Allegro list members:
On July 14, 2008 Paul of Aerosiam wrote the following:
The flap motor operates a vertical screw shaft which rotates in a nylon bushing riveted to the flap actuating arm. It is accessible after removing the white cover behind the pilot's seat.
The screw shaft should be lubricated with lithium grease, I believe.
If a 3 in 1 type oil is applied to the metal screw shaft, it causes the nylon bushing to expand. Over time, flap movement slows and the flap breaker starts popping due to the excess load. The cure is to tap out the nylon bushing until the screw shaft moves freely inside it.
Turning the vertical drive shaft of my plane in de nylon bushing is difficult to be done by hand because of too much friction. To cure this problem, Paul advises to tap out the nylon bushing. But then my question is: which size of thread is in the bushing?
My second question is: is a replacement set of shaft and bushing still available for the Allegro 2000?
Thank you for your comments.
Theo van Duin, France
Allegro 2000
71MM
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
PostPosted: Mon Aug 13, 2012 7:27 am    Post subject: Flap breaker popping Reply with quote
Fellow Allegro list members:
Hugh´s idea of having  a new nut made out of plastic material (not nylon but a better quality material for this porpose) appears to be feasible. I found a machining factory in the Netherlands that is equipped to do this job.
See the site (in Dutch): http://www.mafaha.nl/
They accepted an order for 4 to 5 pieces at a price of 75 Euros a piece. To be sure that the nuts are dimensionally perfect I have to bring them the threaded shaft and the present nylon nut. Bringing them the parts can hopefully be done in a couple of weeks from now.
Whenever you members want to participate in this project, please let me know at t.j.vanduin(at)gmail.com (t.j.vanduin(at)gmail.com)
Theo van Duin (France)
Allegro 2000
71MM
2012/8/4 theo van duin <t.j.vanduin(at)gmail.com (t.j.vanduin(at)gmail.com)>
[quote]Allegro list members:
Allegro 2000
71MM
target="_blank">http://www.matronics.com/Navigator?Allegro-List
tp://forums.matronics.com
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
