Fuel Pump Fittings
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List
Michael Wynn
PostPosted: Thu Oct 18, 2012 7:01 am    Post subject: Fuel Pump Fittings Reply with quote
Hi all,
I am doing the final fuel systems connections on my IO360M1B. I just wanted to verify how the o-ring fittings to the fuel pump work. As I understand it, they are screwed in, more or less finger tight, and positioned for the correct alignment for the hose. Then the outer nut is tightened down which compresses the o-ring and provides the seal. Then the torque setting for the nut would be whatever the table gives for that size nut?  I think it is about 5/16ths, which would translate to around 80 inch pounds.
Do I have this right?
Michael Wynn
RV 8 Finishing
San Ramon, CA
- The Matronics LycomingEngines-List Email Forum -
http://www.matronics.com/Navigator?LycomingEngines-List
Michael Wynn
RV 8
San Ramon, CA
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List All times are GMT - 8 Hours
