Landoll installation...
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List
PGLong
PostPosted: Tue Jun 06, 2006 12:31 pm    Post subject: Landoll installation... Reply with quote
 Hi and thanks Glenn, that is pretty much what I decided to do as there doesn't seem to be much info available.
Pat
Hey Pat,
I use a Landoll Balancer on my -4 and have been very pleased with its'
performance. The documentation you have is all I got when I received mine.
Just follow the picture and look up the bolt torque requirements in the
Aircraft Standards and Procedures Manual (AC 46.13) and you should be set.
Blue Skies,
Glenn Wilkinson
RV-4  N654RV (at) OKZ
- The Matronics RV4-List Email Forum -
http://www.matronics.com/Navigator?RV4-List
Pat Long
RV-4, N120PL
Bay City, MI
smokyray(at)yahoo.com
PostPosted: Tue Jun 06, 2006 1:22 pm    Post subject: Landoll installation... Reply with quote
Glenn, Pat,
  I bought my Landoll balancer at SNF 99' back when Mark used to carry a bunch in his RV4 to the fly-ins. I pulled my cowling at the show, pulled my extension with prop off and bolted it on sans instructions. Piece of cake. It came with grade 8 bolts but I chose aircraft bolts instead and flew home with it.
  It has been on for 1000 hours now in all temperatures and with 4 different props. Definitely improves the smoothness but the real benefit is the flywheel effect and extra 12 lbs on the nose it contributes. I have noticed several things. First it is a race car clutch balancer so it has silicone fluid inside that moves to the heavy and light sides while spinning and takes about 10 hours to settle out. When it does, you will notice an improvement in overall smoothness in cruise. Good call...
Rob Ray
PGLong(at)aol.com wrote:
[quote]  Hi and thanks Glenn, that is pretty much what I decided to do as there doesn't seem to be much info available.
Pat
Hey Pat,
Blue Skies,
Glenn Wilkinson
PGLong
PostPosted: Tue Jun 06, 2006 2:01 pm    Post subject: Landoll installation... Reply with quote
Thanks Smokey
The way you did it, guess I won't even have to pull my spinner!
Pat
Pat Long
RV-4, N120PL
Bay City, MI
PostPosted: Tue Jun 06, 2006 2:28 pm    Post subject: Landoll installation... Reply with quote
Pat,
In fact if you're careful you can slip the alt belt back on when you reinstall the flywheel without loosening the alt bolts...Anytime I need to get to the flywheel or change a belt I always remove the extension from the flange rather than the prop. Much easier...
Re-safety wiring the ext/flange bolts takes the most time for the job!
I like simple...
see ya!
Smokey
[quote] Thanks Smokey
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List All times are GMT - 8 Hours
