				 Posted: Sun Dec 23, 2012 4:26 pm    Post subject: Problem with the Harbor Freight Carbon Pile battery tester |
				I've used this unit a few times without a problem.  Then it suddenly
 stopped working.  I couldn't seem to apply a load though the exact
 symptoms I don't quite remember.
 Today, I pulled the unit apart and found
 1) a fuse on a small circuit board which had not blown (not easily
 replaceable either)
 2) the carbon disks that presumably supplies the variable resistance
 seem to be stacked between two steel plates  but the carbon disks
 appeared to be loose or askew.
 If I screw the big knob down and shake things a bit, I can get the stack
 of carbon plates lined up and it seems that increased resistance results
 from placing more pressure on the stack.
 Does that sound right?
 Furthermore, it would seem for consistent operation, it would be best to
 lie the unit on its back to insure the carbon plates remain flat.
 Tomorrow I will attempt to use it again to see if it works now that the
 plates are back in position.
 Any insight or tips welcome.  I will report further tomorrow.
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
