Gear Tower Covers
graybeard
PostPosted: Mon Mar 18, 2013 1:56 pm    Post subject: Gear Tower Covers Reply with quote
I’ve cut out each gear tower lower web in my QB fuselage and plan to install 0.063 thick covers, but a bit different from what I have seen. I am curious as to whether anyone else has done this and/or if I’m missing something which would make this a bad idea. My covers will have cutouts matching the lower half of the middle hole and upper half of the lower hole. Essentially a very exaggerated “H”. The overall dimensions are 4.13”x7”. Each plate will install with 16 #8 machine screws, probably AN525’s, and AN365 nuts. The primary advantage I see is that this eliminates all the nutplates required with full covers. Also, the holes will be preserved for inspection purposes and in the unlikely event that any maintenance or servicing at all can be done through them. All feedback greatly appreciated.
Stan Loer
RV-8 QB
Mike Koehn
PostPosted: Wed Mar 20, 2013 5:38 pm    Post subject: Gear Tower Covers Reply with quote
Got Pictures or a drawing? That is about my next job on my QB 8.  Saw a mod years ago on the board that looked pretty good but I believe it is a two cover version. Yours may be much better.
Mike Koehn
DogTick
From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of stazel(at)cpros.com
Sent: Monday, March 18, 2013 2:54 PM
To: rv8-list(at)matronics.com
Subject: Gear Tower Covers
Stan Loer
RV-8 QB
"Testing is what we do when we don't know what we are doing"
Dr. Wernher von Braun
