Zenith 650 Question
NCG27
PostPosted: Mon Mar 25, 2013 6:12 pm    Post subject: Zenith 650 Question Reply with quote
Can one of you guys with the CH650 plans give me the dimensions for part number: 6W11-19?
I want to build the rear spar for me XL like the 650 and the plans page that Caleb sent me from Zenith is 6W7 which shows this part, but doesn't give any dimensions or thickness of the material.
Thanks in advance,
Randy B.
Tim Juhl
PostPosted: Wed Mar 27, 2013 3:51 pm    Post subject: Re: Zenith 650 Question Reply with quote
I believe the parts manual calls 6W11-19 a aileron rod hole doubler. Perhaps the info you need may be found on the drawings for the upgrade package which may be viewed at http://www.zenithair.com/zodiac/xl/data/6-ZU-JAN25.pdf
______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring!
