Rollbar support structure - help please!
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List
SSampson.SLN21(at)london.
PostPosted: Sat Jun 10, 2006 11:57 pm    Post subject: Rollbar support structure - help please! Reply with quote
I posted this on Vansairforce yesterday buthavnt found out what I need to know so I will repost here. Apologies if you have to suffer my problems twice!
I am working on the structure that supports the roll bar. It is supported by a piece of 1"*12 angle about 1/3 of which, according to the plans sits completely hiden by the F-416 canopy rail and about 2/3 of which causes you to cut the canopy rail and flatten it out... you remember.
My first attempt resulted in about a 1/4" sticking out at the front as shown in the first picture at http://gikonfuse.blogspot.com/
In the second picture I have shimed the F-417 against the F406 bulkhead and now as you can see the front end of the angle is about flush with the canopy rail.
Should it work out to the plans or has everyone had this problem.
Thanks in advance for the help.
Steve
#4478
UK
- The Matronics RV4-List Email Forum -
http://www.matronics.com/Navigator?RV4-List
n184da(at)volcano.net
PostPosted: Sun Jun 11, 2006 2:10 am    Post subject: Rollbar support structure - help please! Reply with quote
It looks about right to me,,The angle is supposed to sit at an angle,, take the roll bar and "dry fit" to the canopy rails.
Just set it on top of the rails and the angles should match.
Derrick L. Aubuchon
RV-4: N184DA
Jackson/Westover -Amador County (O70)
n184da(at)volcano.net (n184da(at)volcano.net)
I am working on the structure that supports the roll bar. It is supported by a piece of 1"*12 angle about 1/3 of which, according to the plans sits completely hiden by the F-416 canopy rail and about 2/3 of which causes you to cut the canopy rail and flatten it out... you remember.My first attempt resulted in about a 1/4" sticking out at the front as shown in the first picture at http://gikonfuse.blogspot.com/In the second picture I have shimed the F-417 against the F406 bulkhead and now as you can see the front end of the angle is about flush with the canopy rail.Should it work out to the plans or has everyone had this problem.Thanks in advance for the help.Steve#4478UK
PostPosted: Sun Jun 11, 2006 4:38 am    Post subject: Rollbar support structure - help please! Reply with quote
Derrick - thanks for the supportive words. Yes I will check, check and recheck! Steve.
HalBenjamin(at)aol.com
PostPosted: Sun Jun 11, 2006 7:53 am    Post subject: Rollbar support structure - help please! Reply with quote
In a message dated 6/11/2006 6:13:54 AM Eastern Standard Time, n184da(at)volcano.net writes:
It looks about right to me,, The angle is supposed to sit at an angle,, take the roll bar and "dry fit" to the canopy rails.
Derrick L. Aubuchon
RV-4: N184DA
Hi Steve,
Derrick is correct....You need to build to fit.  Be very carefull and check edge distances closely for the mounting bolts.  As I recall, there's not alot of room for error.
Hal Benjamin - RV4
Long Island, NY
Fuselage -
PostPosted: Sun Jun 11, 2006 10:11 am    Post subject: Rollbar support structure - help please! Reply with quote
Hal - thanks, yes it seems to be workig out about right. I suspect VANS plan does not quite represent reality!
Thanks, Steve.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List All times are GMT - 8 Hours
