Quick Build Fuselage Advice
dfritz(at)bpgsim.com
PostPosted: Mon Jun 03, 2013 2:34 pm    Post subject: Quick Build Fuselage Advice Reply with quote
I am starting on my quick build fuselage trying to discover what has
been done and what is left to do. I have removed the floor panels,
except for the front panels, and found only two washers. I think I will
inspect under the front floor panels using an inspection camera. The
heat vent tee, VA-175, in mid fuselage points to the rear of the
fuselage, not up as shown in the plans. I suspect that needs changing.
There is an extra fuel valve mount, F-1048C1, taped to the installed
mount stating that the mount is installed inverted and needs to be
changed. I am installing an Andair valve and from reading Tim's pages I
suspect that I will need to fabricate and bracket so I will need to
simply remove the current one. Insulation seems something that needs
addressing fairly soon. Insulation for the firewall and the tunnel
seems to make sense. I am wondering what insulating the floor would
gain as the noise comes from in front of the firewall, not below the
fuselage. At the risk of starting an insulation war, what insulation
would you recommend? I know Tim mentioned Flightline Interiors.
There appears to be a lot of extras that need to be procured to finish
the plane and at this point in time the issues seem to be ones of timing
the procurement and installations so that something that has been done
does not need to be undone to install an item. Looking at the jig saw
puzzle and trying to see all the pieces and how they fit together.
Dave
Dave Fritzsche
40813
Puyallup, WA
Fuselage
Bob Turner
PostPosted: Mon Jun 03, 2013 2:57 pm    Post subject: Re: Quick Build Fuselage Advice Reply with quote
Just be aware that since Tim built his plane Vans has changed the plumbing and fuel valve location.
Bob Turner
RV-10 QB
EdKranz
PostPosted: Mon Jun 03, 2013 7:43 pm    Post subject: Quick Build Fuselage Advice Reply with quote
I'm just a little ahead of you, and though I went slow build, it's mostly the same from this point on.
You should be able to simply twist the heat vent tee. It's just friction fitted to the fittings that are riveted to the tunnel sides.
As for figuring out what you need to get when, I've just been doing a lot of reading of other's build logs. Some thing that you'll need to figure out coming up soon are:
-- Where you're going to route conduit to the rear
-- Antenna choices if you're going to mount them on the belly
-- Whether or not you want access panels for your step bolts
-- Fuel Pump
-- Fuel Valve
-- Hard line or flexible line for fuel and brakes
Those are just a few of the things I'm working thru right now off the top of my head. Some items may have a significant delay in shipment. I haven't yet had building held up by shipping delays, but I'm sure it's only a matter of time.
Still many more decisions to come!
On Mon, Jun 3, 2013 at 5:33 PM, Dave Fritzsche (Building) <dfritz(at)bpgsim.com (dfritz(at)bpgsim.com)> wrote:
[quote]--> RV10-List message posted by: "Dave Fritzsche (Building)" <dfritz(at)bpgsim.com (dfritz(at)bpgsim.com)>
I am starting on my quick build fuselage trying to discover what has been done and what is left to do.  I have removed the floor panels, except for the front panels, and found only two washers.  I think I will inspect under the front floor panels using an inspection camera.  The heat vent tee, VA-175, in mid fuselage points to the rear of the fuselage, not up as shown in the plans.  I suspect that needs changing.  There is an extra fuel valve mount, F-1048C1, taped to the installed mount stating that the mount is installed inverted and needs to be changed.  I am installing an Andair valve and from reading Tim's pages I suspect that I will need to fabricate and bracket so I will need to simply remove the current one.  Insulation seems something that needs addressing fairly soon.  Insulation for the firewall and the tunnel seems to make sense.  I am wondering what insulating the floor would gain as the noise comes from in front of the firewall, not below the fuselage.  At the risk of starting an insulation war, what insulation would you recommend?  I know Tim mentioned Flightline Interiors.
There appears to be a lot of extras that need to be procured to finish the plane and at this point in time the issues seem to be ones of timing the procurement and installations so that something that has been done does not need to be undone to install an item. Looking at the jig saw puzzle and trying to see all the pieces and how they fit together.
Dave
Dave Fritzsche
40813
Puyallup, WA
Fuselage
http://forums.matronics.com
le, List Admin.
Ed Kranz
RV10
Finishing
www.edandcolleen.com
nukeflyboy
PostPosted: Tue Jun 04, 2013 4:38 am    Post subject: Re: Quick Build Fuselage Advice Reply with quote
I used fiberglass insulation under the forward floor panels. This can be added via the lightening holes on the aft side of the floor so you don't have to remove the panel. In the rear seat and baggage compartment I used closed cell foam. Having said that I am not convinced that it is worth it. For heat insulation you need to focus on the firewall and tunnel. Most of the noise in the airplane comes from the air vents, followed by engine. I doubt the floor insulation does much.
As stated in the earlier response this is the time to figure your electrical routing, i.e., conduit and big cable runs. Under the floor is a good place for this, in particular thru the baggage compartment. Don't forget electrical and antenna runs to the wings which will pass via the center section fuselage. Consider adding conduit from front to aft of the baggage bulkhead, conduit from front to each wing opening, and front to the center section (for things like flap motor, rear seat headphones, and antenna cable).
Dave Moore
RV-6 built and sold
RV-10 built and flying
AirMike
PostPosted: Tue Jun 04, 2013 8:49 pm    Post subject: Quick Build Fuselage Advice Reply with quote
I affirm what Dave Moore said...."run lots of the conduit now." Excellent advice. I also put in an inspection plate (2) for the boarding step WHEN it loosens (which it will). It is also a good idea to put it in just for corrosion inspections. There is an excellent and ultra light insulation that I found at OSH. I also have the heavy - foil backed fiberglass on the cowl and firewall. I never had the tunnel heat issue. My tunnel is NOT insulated. I found that the fuel lines are a real pain, so I bought the Bonaco kit - excellent choice and saved me a lot of swearing. I have nothing but kuddos for the Vans QB kit that was delivered to me in 2007.
See you OSH '18
Q/B - sold.
Kelly McMullen
PostPosted: Tue Jun 04, 2013 9:29 pm    Post subject: Quick Build Fuselage Advice Reply with quote
I seem to recall folks have had trouble with the AN 3 bolts Vans supplies for steps wearing the hole and loosening. There are three possible upgrades. Putting inspection plate on baggage floor as mentioned, reaming the holes up to AN 4 size, and inserting dowel of wood, or milled aluminum or steel inside the step pipe to prevent the pipe from being distorted by tightening the bolt(with appropriate anti-corrosive treatment). I have done the first two items.
On Tue, Jun 4, 2013 at 9:49 PM, AirMike <Mikeabel(at)pacbell.net (Mikeabel(at)pacbell.net)> wrote:
--> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net>
See you OSH '13
Q/B - flying 3 yrs.
http://forums.matronics.com/viewtopic.php?p=402047#402047
le, List Admin.
- sent from the microchip implanted in my forearm
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Mauledriver(at)nc.rr.com
PostPosted: Wed Jun 05, 2013 7:04 am    Post subject: Quick Build Fuselage Advice Reply with quote
Some thoughts from a 2011 completion and 300 hours later.
On 6/3/2013 11:42 PM, Ed Kranz wrote:
As for figuring out what you need to get when, I've just been doing a lot of reading of other's build logs. Some thing that you'll need to figure out coming up soon are: -- Where you're going to route conduit to the rear
I went with the Vans wiring kit routing hardware to run fat power wires and some other lines. It has a few brackets and and clamp locations. I did not buy or use the Vans wiring kit or configuration, just used the plans to mimic their routing and order a few select pieces (plus some access hatches and avionic mounts for the tail). Then, I ran 2 empty conduits (Van's material) for running all the avionics stuff that were going to be finalized after the floor was closed. 3 empty conduits is even better. This has all worked very well.
I had some churn around antenna choices. Ultimately I found that with one comm antenna installed under the floor before the floor is closed up, additional antennas could be added after completion (e.g. transponder, another comm under the seat, ADS-B and ELT stuff is all in the tailcone and remains accessible (see desirability of 3rd conduit))
-- Fuel Pump
-- Fuel Valve
I did it exactly per Vans plus Andair mods. Still doing fine at 300hours on a rough field (think brake lines). You don't have to learn to bend aluminum tubing if you get the flexible lines I guess. I learned but have been unable to transfer the skills to much of anything else.
The decisions are the real joy of the project. not withstanding that Vans per the plans works too. "Less is more" applies as does "but Mama, that's where the fun is"
I have a Flightline interior which probably deadens some sound. We like it because it looks nice and works well. Otherwise we depend on Bose (or your favorite ANL device). I put some low tech material on the back of the firewall, don't know if it does anything. You don't need to insulate in my opinion. A painted interior and good ANL headsets would seem to do the trick. It's up to you where you want to spend your time.
Dave
johngoodman
PostPosted: Thu Jun 06, 2013 8:28 am    Post subject: Re: Quick Build Fuselage Advice Reply with quote
I used an AN174 close tolerance bolt from Spruce. No wobble yet.
John
