C of G range
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
sprocket(at)vx-aviation.c
PostPosted: Fri Jun 21, 2013 6:25 pm    Post subject: C of G range Reply with quote
What is the official c of g range for the HR-II?
The RV-4 range is 15 to 30 percent of MAC (8.7 to 17.4 inches aft of leading edge), but I have seen other numbers for the HR-II.
Thanks, Vern
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
viperpilot
PostPosted: Sun Jun 23, 2013 8:05 am    Post subject: Re: C of G range Reply with quote
The latest information I have is a CG range of 86.7 inches to 97.4 inches aft of the "Datum". The "Datum" is 80.0 inches forward of the wing leading edge. Source of the information is John Harmon at harmonrocket(at)aol.com . Hope that helps. Feel free to email me at viperplt(at)comcast.net if you have any further questions.
Tailwinds,
Randy Sage
PostPosted: Sun Jun 23, 2013 10:16 am    Post subject: C of G range Reply with quote
Hi Randy, thanks for this.
My research has shown that the RV-4 wing uses 15-30 percent MAC which is
88.7 to 97.4 inches aft of datum.
I've seen the 86.7 and 87.7 forward limit in some F1 cases (larger tail),
but this is quite an outlier. Virtually all loading cases can fit within
the 88.7 limit (155 lb pilot, zero fuel is at the limit in my case). Note
that fuel moment arm is AFT of the forward limit, so the C of G moves
forward as fuel is burned in this scenario!
The only traceable engineering source is the RV-4 manual and I'm happy with
the choice off 88.7 for the forward limit. Everyone agrees on the aft
limit!
Thanks again for the feedback,
Vern
nrsage86(at)comcast.net
PostPosted: Mon Jun 24, 2013 6:23 am    Post subject: C of G range Reply with quote
Vern,
Glad to help. Good luck on getting her airborne. Fly Safe!
Randy
PostPosted: Mon Jun 24, 2013 4:10 pm    Post subject: C of G range Reply with quote
First engine start was today, no problem except for the prop governor
working in reverse (sigh).
Thanks, V
rktman64(at)gmail.com
PostPosted: Mon Jun 24, 2013 6:10 pm    Post subject: C of G range Reply with quote
Congratulations Vern!
Kevin
On Jun 24, 2013, at 5:13 PM, "Vern Little" <sprocket(at)vx-aviation.com> wrote:
First engine start was today, no problem except for the prop governor working in reverse (sigh).
Thanks, V
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
