		asc23111964(at)hotmail.co Guest
				 Posted: Fri Jul 05, 2013 10:33 am    Post subject: Outside aircraft |
				Hi Richard,
 Thanks for your message,personally I would never leave DH outside for any
 Appreciable time,with or without covers.
 I've done quite a bit of gliding in my time,so I'm well familiar with composites and their draw-backs.
 Did you sand back,dry out and re-paint
 Your tailplanes?
 The aircraft I saw here in the U.K.at first
 Looked ok,but on closer inspection,it was obvious it was in a sorry state,with
 Quite a few blisters mid-way on the D-box on the wing,..just where you don't want to see them.
 So,it looks like it would require major strip dry out at 35-40 c dehumidifiers,
 Silica gel etc,and even then there could
 Be underlying freezing damage to the structure,which would require investigation before any re-painting was
 carried out.
 If you do leave your aircraft out,a polish with good old beeswax is a good tip to help keep the water out.
 Best Regards
 Andy Cullum.
		Fred Klein
				 Posted: Fri Jul 05, 2013 3:23 pm    Post subject: Outside aircraft |
				Sounds to me like this ship would deserve full sand bagging for checking POS and NEG G-loading before flight test...
 On Jul 5, 2013, at 11:33 AM, andrew cullum wrote:
  carried out.
				 Posted: Fri Jul 05, 2013 3:53 pm    Post subject: Outside aircraft |
				Yes,good point Fred.
 Just to illustrate my point,a few years ago there was a Rallye Minerva parked at a local airfield.
 It had a composite Hoffman variable pitch propellor,almost brand new.
 Sadly, the owner hadnt paid the bill for
 Maintenance,so the company put it outside,without removing the propellor.
 It remained outside for about 18 months,which meant particularly cold temps in winter,snow etc.
 I examined the prop and lo and behold,
 Every blade had a nasty crack at the base close to the vari pitch hub,about 2" long....water ingress and freezing damage obviously.
 I rest my case.
 Andy Cullum.
 On 6 Jul 2013, at 00:28, "Fred Klein" <fklein(at)orcasonline.com> wrote:
 > carried out.
		graeme bird
				 Posted: Sat Jul 06, 2013 11:24 am    Post subject: Re: Outside aircraft |
				I can't understand the motivation for these threads, this and the one re G KITS, unless I am being thick it sounds like someone has wandered up to someone elses plane seen letters faded etc and proceeded to have a public, in print for all time, slagging off of it and its state. Is this a good way to carry on? This doesnt sound like the europa forum to me. Even if there were facts rather than views it wouldnt be fair.
  _________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY -  Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
		stranfaer(at)btinternet.c Guest
				 Posted: Sun Jul 07, 2013 2:11 am    Post subject: Outside aircraft |
				Agreed.................
 We will all be able to criticise another aircraft if we want too, there but for the grace of God go I
 from the other one!
 Sent to you from David Joyce
 www.eastmidsspas.com
  Sent: Saturday, 6 July 2013, 20:24
  Subject: Re: Outside aircraft
 --> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
 Graeme Bird
 G-UMPY
 Mono Classic/XS 912S/Woodcomp 3000/3W
 Newby: 75 hours 18 months
 g(at)gdbmk.co.uk
 http://forums.matronics.com/viewtopic.php?ronics.com/Navigator?Europa-List" ="http://forums.matronics.com/" target="_blank">http://forums.matronics                     tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
