Nulon L90 grease
jlcrowder(at)gmail.com
PostPosted: Tue Jul 30, 2013 11:45 am    Post subject: Nulon L90 grease Reply with quote
Looking for a reasonable source to ship to USA address, Nulon L90 grease. Jabiru seems very proud of this product. Super Lube brand High Temperature Extreme Pressure Grease seems to be to my inexperienced eye very similar, but it is $40 plus shipping and I am not confident it is equal. Any feedback would be appreciated.
Jim Crowder
BARRY CHECK 6
PostPosted: Tue Jul 30, 2013 1:04 pm    Post subject: Nulon L90 grease Reply with quote
James:
EP Grease is available for all sorts of applications.  The MSDS from NULON is not acceptable for import into the USA but if you read the Product Bulletin you will find it is polytetrafluoroethylene (PTFE) base.  That means it is a TEFLON base.  Better than teflon for lubrication would be a Marine Grease with Moly (Molybdaenum) Disulfide.  Matter of FACT there is NO other DryLube that can stand up to it or has the lowest coefficient of friction.  The suggestion for Marine Grease is stand up to all levels of moisture.  An expensive moly grease would cost $7 for a 14 oz tube; $12 if purchased at a marine store.
Barry
“Chop’d Liver”
On Tue, Jul 30, 2013 at 3:44 PM, James Crowder <jlcrowder(at)gmail.com (jlcrowder(at)gmail.com)> wrote:
Jim Crowder
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
tp://forums.matronics.com
PostPosted: Tue Jul 30, 2013 1:18 pm    Post subject: Nulon L90 grease Reply with quote
Thanks, I’ll check it out.
Jim
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of FLYaDIVE
Sent: Tuesday, July 30, 2013 2:04 PM
To: jabiruengine-list(at)matronics.com
Subject: Re: Nulon L90 grease
James:
Barry
“Chop’d Liver”
Jim Crowder
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution
