CJ6 (Housai) temp problem
pnicholson
PostPosted: Tue Aug 13, 2013 4:35 am    Post subject: CJ6 (Housai) temp problem Reply with quote
Good morning,
I have two problems that may or may not be related.
My CHT is lower than normal which requires me to be running the shutters closed occasionally; the temps appear colder than usual.  A little further back, my oil temps are running hotter than normal.  Seems a little counter-intuitive.
Details:
Cruise,
3500'
75 degrees out...
Any thoughts appreciated.
Phil Nicholson
C-FEPN
(Ontario)
keithmckinley
PostPosted: Tue Aug 13, 2013 6:02 am    Post subject: Re: CJ6 (Housai) temp problem Reply with quote
there are no details posted. a "little this" and a "bit more" are hard to use to make an informed analysis...just sayin'
N13472(at)aol.com
PostPosted: Tue Aug 13, 2013 9:04 am    Post subject: CJ6 (Housai) temp problem Reply with quote
I run with my shutters and oil door ¾ to fully closed when in temps 80 or lower except during
a steep long climb.
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV
89019
Cell 541-297-5497
N13472(at)AOL.COM
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Philip Nicholson
Sent: Tuesday, August 13, 2013 5:33 AM
To: Yak-List
Subject: CJ6 (Housai) temp problem
Good morning,
Details:
Cruise,
3500'
75 degrees out...
Phil Nicholson
C-FEPN
(Ontario)
Checked by AVG - www.avg.com
Version: 2013.0.3392 / 08/12/13
richard.goode(at)russiana
PostPosted: Tue Aug 13, 2013 6:05 pm    Post subject: CJ6 (Housai) temp problem Reply with quote
In which case I suspect your engine is running significantly too rich and you're wasting quite a lot of money on fuel!
I have no experience with the HS-6 engine, but would assume that the carburettor must be extremely similar to the Russian carburettor which contains what the Russians call a "suction" jet, but I would call "compensating" in which a smaller jet means more fuel. These come in a range from 1.1 to 2.0 mm; are very easy to change. The right jet should be installed based on its ability to keep cylinder temperatures in the right range, and for most engines this will reduce fuel consumption.
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +94 (0) 81 241 5137 (Sri Lanka)
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
I’m currently in Sri Lanka but this Mail is working,and my local phone is +94 779 132 160.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Tom Elliott
Sent: Tuesday, August 13, 2013 10:31 PM
To: yak-list(at)matronics.com
Subject: RE: CJ6 (Housai) temp problem
a steep long climb.
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV
89019
Cell 541-297-5497
N13472(at)AOL.COM (N13472(at)AOL.COM)
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Philip Nicholson
To: Yak-List
Good morning,
Details:
Cruise,
3500'
75 degrees out...
Phil Nicholson
C-FEPN
(Ontario)
 http://www.matronics.com/Navigator?Yak-List http://forums.matronics.com http://www.matronics.com/contribution
believed to be clean.
wlannon(at)shaw.ca
PostPosted: Tue Aug 13, 2013 6:13 pm    Post subject: CJ6 (Housai) temp problem Reply with quote
Phil;
I concur with Tom Elliot’s comments. That is typical of CJ operating temperatures.
A little difficult to understand your problem. You show cruise at 3500 ft. with a temperature of 75 degs. ?? Is that the OAT or the Oil Out temp.? If it is Oil Out you are running far too cold.
Except in very hot weather it is difficult to maintain adequate Oil In temperature. Please clarify.
Walt
To: Yak-List (Yak-List(at)matronics.com)
Good morning,
Details:
Cruise,
3500'
75 degrees out...
Phil Nicholson
C-FEPN
(Ontario)
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
keithmckinley
PostPosted: Tue Aug 13, 2013 6:24 pm    Post subject: Re: CJ6 (Housai) temp problem Reply with quote
your CJ is only reading one cyl on the front gauge. The cyl head temps vary widely from cyl to cyl
Do you know if your oil temp and or cyl head sensors and gauges are even indicating correctly?
When was the last time you pulled and cleaned your oil cooler? Lot's of oil goes down there and picks up lots of dirt.
N13472(at)aol.com
PostPosted: Tue Aug 13, 2013 8:26 pm    Post subject: CJ6 (Housai) temp problem Reply with quote
Not rich I have mixture control and EGT. At altitude can lean to lean of peak
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV
89019
Cell 541-297-5497
N13472(at)AOL.COM
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Richard Goode
Sent: Tuesday, August 13, 2013 7:03 PM
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Tom Elliott
a steep long climb.
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV
89019
Cell 541-297-5497
To: Yak-List
Good morning,
Details:
Cruise,
3500'
75 degrees out...
Phil Nicholson
C-FEPN
(Ontario)
5
6
7
8
9
Version: 2013.0.3392 / 08/13/13
samira.h(at)shaw.ca
PostPosted: Wed Aug 14, 2013 6:59 am    Post subject: CJ6 (Housai) temp problem Reply with quote
Phil,
Keith might have a point.
Did you check the accuracy of
your Cyl.-head-temp gauge
set-up???
The lead from the thermocouple
to the instrument has a fabric
insulation what disintegrates over
the years. If that happens your
readings will be off and inaccurate(ly).
As far as I remember, Doug Sapp has
those leads in stock and that might be
a cheap fix for your problem.
Good luck.
cheers
Elmar
