Rudder Pedal Positon
LarryRosen(at)comcast.net
PostPosted: Sat Jan 14, 2006 7:10 am    Post subject: Rudder Pedal Positon Reply with quote
I am working on the rudder pedal installation. It seems that there is
an option for the mounting position of the pedals. The bearing block
could be mounted to the longeron in two different positions. I am 5'-9"
and I think that the forward position would be the appropriate choice.
What do you all think?
Would it be prudent to drill the center bearing block for both positions
so the pedals could be moved easier in the future?
Larry Rosen
40356
<http://lrosen.nerv10.com>
rick.conti(at)boeing.com
PostPosted: Sat Jan 14, 2006 7:25 am    Post subject: Rudder Pedal Positon Reply with quote
I'm 5 8 and moved the peddals aft.
Thank You
Rick Conti
The Boeing Company
Sent from my BlackBerry Wireless Handheld
weeav8ter(at)grandecom.ne
PostPosted: Sun Jan 15, 2006 3:44 am    Post subject: Rudder Pedal Positon Reply with quote
I drilled both positions on mine. Who knows I may get taller.
Wayne Edgerton
40336
