Finding a 0.25A fuse
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Aerobatic-List
jhclarkfl
PostPosted: Thu Mar 17, 2011 5:29 am    Post subject: Finding a 0.25A fuse Reply with quote
This may seem like a simple problem with an easy solution. But I'm quite sure about what to use and how to install this circuit protection.
A circuit I am wiring requires a small 0.25A fuse. The problem I am having is finding a 0.25A fuse for the 12V system. Most fuses I find are for 125V and 250V.
What would those in the know suggest for installing this fuse? I see glass cylinder fuses for probably bulky fuse holders and I see some with pigtails on them for soldering inline. Is there other better ideas?
- The Matronics Aerobatic-List Email Forum -
http://www.matronics.com/Navigator?Aerobatic-List
Jack Clark
RV-8A Fuselage
http://www.mykitlog.com/jackclark/
pa3arw(at)euronet.nl
PostPosted: Thu Mar 17, 2011 6:10 am    Post subject: Finding a 0.25A fuse Reply with quote
John,
You can use both fuses for your circuit.
In your case the most important parameter is the current, not the voltage.
How you to implement that is up to you and the mechanical choices you make (
or have been made for you...) to fit the fuse. I suggest not to use "in
line" fuses. Try to use fuses which can be reached easily and at all times.
Fly safe!
Hans
-----Oorspronkelijk bericht-----
Van: owner-aerobatic-list-server(at)matronics.com
[mailto:owner-aerobatic-list-server(at)matronics.com] Namens jhclarkfl
Verzonden: donderdag 17 maart 2011 14:30
Aan: aerobatic-list(at)matronics.com
Onderwerp: Finding a 0.25A fuse
and 250V.
Jack Clark
RV-8A Fuselage
http://forums.matronics.com/viewtopic.php?p=334180#334180
jhclarkfl
PostPosted: Thu Mar 17, 2011 7:22 am    Post subject: Re: Finding a 0.25A fuse Reply with quote
Thanks Han for your rely.
Jack Clark
RV-8A Fuselage
MyJuliet
PostPosted: Fri Jul 29, 2011 6:53 pm    Post subject: Re: Finding a 0.25A fuse Reply with quote
I need a small wiring circuit of 0.25A fuse. I encountered the problem is to find a system for 12V 0.25A fuse. Most of the fuse, I think for the 125V and 250V.
jacob374
PostPosted: Mon Oct 07, 2013 8:29 pm    Post subject: Re: Finding a 0.25A fuse Reply with quote
Thanks Han for your rely....?
Training
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Aerobatic-List All times are GMT - 8 Hours
