vernon.franklin(at)gmail. Guest
Posted: Sat Nov 02, 2013 11:23 am Post subject: Front Tire Installation |
Has anyone run into this situation? Either my U-1009 Axle is to
short, or my U-1023 spacers are to long. You can see by the attached
pictures that I am about 1/8" short on the axle.
When I went to install the wheel, and torqued the AN6, the wheel
didn't turn very well. All of the pressure appears to be placed on
the spacers as opposed to the axle.
I verified the wheel halves are tight against each other.
Any ideas?
Vernon Franklin
90.85 KB |
2541 Time(s) |
87.85 KB |
2541 Time(s) |
Posted: Sat Nov 02, 2013 1:46 pm Post subject: Front Tire Installation |
That is the way it is supposed to be. The spacers are supposed to put a preload on the bearings so the axle doesn't turn. In the past I have turned down the axle w little to increase the preload. The wheel will not turn very freely, but you want to make sure the spacers do NOT turn, but rather the wheel turns while the bearings don't.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
| Quote: | On Nov 2, 2013, at 3:22 PM, Vernon Franklin <vernon.franklin(at)gmail.com> wrote:
Any ideas?
Vernon Franklin
<20131102_135338.jpg>
<20131102_135324.jpg>
Kelly McMullen
Posted: Sat Nov 02, 2013 9:47 pm Post subject: Front Tire Installation |
Easily cured with a Matco axle in place of Van's home brew solution.
Lets you set preload on bearings independent of the nose gear forks.
On Sat, Nov 2, 2013 at 12:22 PM, Vernon Franklin <vernon.franklin(at)gmail.com (vernon.franklin(at)gmail.com)> wrote:
| Quote: | Has anyone run into this situation? Either my U-1009 Axle is to
Any ideas?
Vernon Franklin
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
bill.peyton
Posted: Sun Nov 03, 2013 6:49 am Post subject: Re: Front Tire Installation |
I would definitely order the Matco axle. It allows you to pre-load the bearings independent of tightening the axle nut. I think you will find a thread in regards to this issue either here or on VAF.
_________________ Bill
WA0SYV
Aviation Partners, LLC |
Posted: Mon Nov 04, 2013 7:51 am Post subject: Front Tire Installation |
Thank you. Found it, and ordered the Matco axle and spacers.
Next question, on the main's bearings, is it advised to grease up the
felt dust covers or leave them dry?
What is the best practice with these?
Vernon
On Sun, Nov 3, 2013 at 8:49 AM, bill.peyton <peyton.b(at)sbcglobal.net> wrote:
WA0SYV
http://forums.matronics.com/viewtopic.php?p=411996#411996
Vernon Franklin
