thimble+cable eye?
psm(at)att.net
PostPosted: Sat Nov 23, 2013 8:05 pm    Post subject: thimble+cable eye? Reply with quote
Hi Carlos,
Yes, I believe you should always use a thimble on cable loops.
I wouldn't worry about the thimble being a little deformed. The point is to keep the wear from destroying the cable. The thimble takes the abuse that would otherwise start breaking cable strands.
Paul
Camas, WA
XL collecting dust and getting lonely.
On 11/23/2013 7:59 PM, Carlos Sa wrote:
[quote] Hello, folks
When you swage a cable, you always use a thimble, right?
When swaging a cable that goes through a turnbuckle's cable eye, I am feeling a little uncomfortable with the idea of deforming the thimble to put it through cable eye hole...
Just want to make sure I am not doing anything wrong...
Thanks in advance for any comments
Carlos
steve.freeman(at)syntaxds
PostPosted: Sat Nov 23, 2013 8:42 pm    Post subject: thimble+cable eye? Reply with quote
Always use a thimble!  You have to spread the thimble a little to get it through the eye of the pin but then gently squeeze back together with pliers after.
There is a really good article on swaging cables in Kit Planes magazine this month.
Steve Freeman877-733-4390
Sent from my Mobile device. Please excuse the brevity and any typing errors.
On Nov 23, 2013, at 21:07, "Carlos Sa" <carlossa52(at)gmail.com (carlossa52(at)gmail.com)> wrote:
[quote]Hello, folks
Carlos
rvsimons
PostPosted: Sat Nov 23, 2013 9:14 pm    Post subject: thimble+cable eye? Reply with quote
You are correct. Bending the thimble a little is necessary to get it into the eye. I try and pry the thimble open with a screw driver just enough to get it through the eye without bending it to much then I install the cable through it and swedge it. When crimping I keep the thimble from coming in direct contact with the nico press collar. Some people run them up tight together.
Good luck On Nov 23, 2013 8:04 PM, "Carlos Sa" <carlossa52(at)gmail.com (carlossa52(at)gmail.com)> wrote:[quote] Hello, folks
Carlos
_blank">www.aeroelectric.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
arget="_blank">http://www.matronics.com/Navigator?Zenith-List
tp://forums.matronics.com
Vance Simons
Post Falls, Idaho
Zenith 701
psm(at)att.net
PostPosted: Sat Nov 23, 2013 9:55 pm    Post subject: thimble+cable eye? Reply with quote
Another way to get the thimble through the little hole is to twist it so the ends are not facing each other. This allows you to insert it and then just twist it back.
Paul
Camas, WA
Hello, folks
Carlos
ank">www.mrrace.com
BARRY CHECK 6
PostPosted: Sun Nov 24, 2013 3:37 am    Post subject: thimble+cable eye? Reply with quote
Carlos:
Take a look in AC 43-13 and even in ACS catalog.  They will show how and where it is done.
*Barry*
*“Chop’d Liver”*
NJ has taken the next step.  They are identifying cars with bad drivers.  You will notice some cars with a large red "R" on them.   That is to identify the drivers as "R"estricted.  Restricted is just a polite way of saying Bad Drivers.  Be cautious around them.
On Sat, Nov 23, 2013 at 10:59 PM, Carlos Sa <carlossa52(at)gmail.com (carlossa52(at)gmail.com)> wrote:
Carlos
ank">www.mrrace.com
jaybannist(at)cs.com
PostPosted: Sun Nov 24, 2013 6:22 am    Post subject: thimble+cable eye? Reply with quote
Another tip --  I honestly can't recall why, but my EAA tech adviser (Mel Asberry) told me to always clip off those sharp pointed tips on the thimble.
Jay
rvsimons
PostPosted: Sun Nov 24, 2013 6:34 am    Post subject: thimble+cable eye? Reply with quote
Good point Jay. You are correct. I was told this was to keep the thimble from binding against the nico press sleeve. I was also told to make sure to smooth the ends you cut with a file so there is no burrs to rub on the wire. Common sense really.
Vance On Nov 24, 2013 6:25 AM, "Jay Bannister" <jaybannist(at)cs.com (jaybannist(at)cs.com)> wrote:[quote] Another tip  --  I honestly can't recall why, but my EAA tech adviser (Mel Asberry) told me to always clip off those sharp pointed tips on the thimble.
Jay
ank">www.mrrace.com
Vance Simons
Post Falls, Idaho
Zenith 701
BARRY CHECK 6
PostPosted: Sun Nov 24, 2013 8:53 am    Post subject: thimble+cable eye? Reply with quote
Yes, Jay:
The reason is if/when the cable flexes the eye ends do not cut/rub on the enter & exit cable.  BUT!  You also have to smooth the eye by fine wheel grinding.
*Barry*
*“Chop’d Liver”*
On Sun, Nov 24, 2013 at 9:21 AM, Jay Bannister <jaybannist(at)cs.com (jaybannist(at)cs.com)> wrote:
Jay
ank">www.mrrace.com
PostPosted: Sun Nov 24, 2013 9:32 am    Post subject: thimble+cable eye? Reply with quote
Gents, thank you all for the comments!
Carlos
On 23 November 2013 22:59, Carlos Sa <carlossa52(at)gmail.com (carlossa52(at)gmail.com)> wrote:
Carlos
paulrod36(at)msn.com
PostPosted: Mon Nov 25, 2013 2:35 pm    Post subject: thimble+cable eye? Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Jay, I was told the same thing a long time ago, but the reason I was given was that you got the thimble closer to the swage, thereby avoiding some slop in the loop. I don't know if it's true or not, but it sounds good...
Paul R..
