MTOW of RV-6 with Lycoming O-320-D3G and 79" Sensenich Fix
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
ceengland7(at)gmail.com
PostPosted: Mon Jan 06, 2014 5:49 pm    Post subject: MTOW of RV-6 with Lycoming O-320-D3G and 79" Sensenich Fix Reply with quote
What analysis did you use to arrive at the opinion that the -7's
structure is weaker than the -6?
Charlie
On 1/6/2014 5:00 PM, bigdog(at)bentwing.com wrote:
What aspect do you need to justify? Performance or structure or both or just that someone else has done it? If performance, what standard has to be met? An RV will beat most factory airplanes at almost any weight. I don't know if Van's has ever admitted to more than 1650 for the RV-6 but the RV-7/a shows an 1800 lb GW and its structure is IMHO weaker than the -6. If the RV-7 analogy works then just point to Van's web site. http://www.vansaircraft.com/public/rv7specs.htm
Greg Young
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
