Lightning-List Digest: 6 Msgs - 01/29/14
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
sumner135(at)gmail.com
PostPosted: Mon Feb 03, 2014 7:38 am    Post subject: Lightning-List Digest: 6 Msgs - 01/29/14 Reply with quote
Is there video yet of the XS flight???
-Aaron
On Thu, Jan 30, 2014 at 2:00 AM, Lightning-List Digest Server <lightning-list(at)matronics.com (lightning-list(at)matronics.com)> wrote:
[quote]*
Today's complete Lightning-List Digest can also be found in either of the
two Web Links listed below.  The .html file includes the Digest formatted
and Message Navigation.  The .txt file includes the plain ASCII version
of the Lightning-List Digest and can be viewed with a generic text editor
HTML Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2014-01-29&Archive=Lightning
Text Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2014-01-29&Archive=Lightning
                           Lightning-List Digest Archive
                     Total Messages Posted Wed 01/29/14: 6
Today's Message Index:
     1. 11:59 AM - Re: Enjoy the little things, like adding air to the tires  (N1BZRich(at)AOL.COM (N1BZRich(at)AOL.COM))
     2. 04:04 PM - Lightning XS nears first flight  (Nick Otterback)
     3. 04:31 PM - Re: Lightning XS nears first flight  (Jack Gonzenbach)
     4. 04:31 PM - Re: Lightning XS nears first flight  (Philip Abernathy)
     5. 04:38 PM - Re: Lightning XS nears first flight  (N1BZRich(at)AOL.COM (N1BZRich(at)AOL.COM))
     6. 05:45 PM - Re: Lightning XS nears first flight  (Egose45)
________________________________  Message 1  _____________________________________
Time: 11:59:09 AM PST US
Subject: Re: Enjoy the little things, like adding air to the tires
Hi Bill,
    Thanks for the input.  Looks like a good "tech  tips" item for the next
(and last) newsletter that I will write.  Dennis  Wilt will take over then
- probably just after Sun N Fun.
Blue Skies,
Buz
In a message dated 1/29/2014 12:32:11 A.M. Eastern Standard Time,
bill(at)gdsx.com (bill(at)gdsx.com) writes:
-->  Lightning-List message posted by: "Bill Strahan"  <bill(at)gdsx.com (bill(at)gdsx.com)>
Yep, sometimes the little things make a  difference.  First, let me show a
picture of my "minimum travel  kit"
The ratcheting screwdriver on top has a screw off cap and holds  several
bits in the handle.  Flat head, small phillips, 1/4" drive for  the sockets.
It also has a set of screws and washers for the matco  brakes in there as
well as the star drive for the screws in case I have to  remove a wheel while
on a trip and I break one of the little  screws.
Below that is my set of sockets, and the 3/8" socket is removed  because it
relates to the subject of adding air to the tires.  More on  that later.
Next is my valve stem extension.  Originally the end  that screws onto the
stem was free to turn.  Epoxy and flox took care of  that, as you can see.
The extension normally has a valve stemp cap on  it, but it's removed and
separate in this photo.
Next is my socket  extension, and finally in the bottom left corner is a
handy 1/4" socket drive  that is meant to be used with thumb and fingers.
It's tiny, and super  useful.  My wheelpants sit low and are a tight fit.  For
the bottom  screws I can put a 5/16" socket on that thumb drive, put a
phillips bit in the  socket, and I have a very short ratcheting screwdrive for
that  purpose.
Now, back to the tires.  There is a lot written about  determining where to
put the hole in the wheelpants, so I won't reiterate that  here.  I'll just
add that it is well worth the time to find a way to mark  the tire sidewall
with a bit of paint so you can tell when the valve stem is  lined up with
that hole without having to peer into it while moving the  plane.
So, get the valve stem lined up with the hole in the  wheelpants.  Put the
3/8" socket on the socket extension, slide it  through the hole and onto the
valve stem cap.  Unscrew the cap (It should  have just been finger tight)
and pull it back while trying to keep it in the  socket.  Set that aside.
Take the valve stem extension and slide  it through the hole in the
wheelpants and thread it onto the valve stem.   You'll have an easy time of it
if
you try to duplicate the angle at which you  were holding the 1/4" drive
extension.  Once it's finger tight you can  check tire pressure and add or
remove air.  When done, reverse the  process.
I keep the valve stem cap on the extension in case I ever lose  a cap while
doing this away from home.
So, nothing earth shattering  here, but having a defined process and plan
for the little things makes them  go quick and easy.
Read this topic online  here:
http://forums.matronics.com/viewtopic.php?p=417807#417807
http://forums.matronics.com//files/img_3716a_168.jpg
________________________________  Message 2  _____________________________________
Time: 04:04:49 PM PST US
Subject: Lightning XS nears first flight
From: Nick Otterback <vettin74(at)yahoo.com (vettin74(at)yahoo.com)>
We are awaiting our inspection for N320XS the first Lightning XS to be built. All
systems are working properly and we have about an hour of taxing around.
Made our first full power run today on the runway and i am very happy to report
that directional control if very easy and little rudder input is required to
track straight. The prop is bigger yes but the prop disc is 7" closer to the cg,
this coupled with the correct offset make for good takeoff tracking.
I can tell you that bringing up 160hp on a 1,000lb airframe is a kick in the pants
for sure.
Nick
Sent from my pocket
________________________________  Message 3  _____________________________________
Time: 04:31:12 PM PST US
From: "Jack Gonzenbach" <jgonzenbach(at)jegcons.com (jgonzenbach(at)jegcons.com)>
Subject: RE: Lightning XS nears first flight
Get some video of the first flight and post it on UTube! Can't wait to see
it.
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
PostPosted: Mon Feb 03, 2014 8:23 am    Post subject: Lightning-List Digest: 6 Msgs - 01/29/14 Reply with quote
The XS is being inspected today and we will fly the next reasonable weather day we get. When we fly there will be some vids.
Nick
Sent from my pocket
On Feb 3, 2014, at 9:37 AM, "135Sumner ." <sumner135(at)gmail.com> wrote:
[quote] Is there video yet of the XS flight???
-Aaron
On Thu, Jan 30, 2014 at 2:00 AM, Lightning-List Digest Server <lightning-list(at)matronics.com> wrote:
> HTML Version:
> Text Version:
> 1. 11:59 AM - Re: Enjoy the little things, like adding air to the tires (N1BZRich(at)AOL.COM)
> 5. 04:38 PM - Re: Lightning XS nears first flight (N1BZRich(at)AOL.COM)
> From: N1BZRich(at)AOL.COM
> Hi Bill,
> Blue Skies,
> Buz
> bill(at)gdsx.com writes:
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
