Failure mode of a vernatherm?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List
FisherPaulA(at)johndeere.
PostPosted: Sun Apr 27, 2014 7:59 am    Post subject: Failure mode of a vernatherm? Reply with quote
What is the failure mode of a vernatherm? Do they just completely fail or start to "go bad". I pulled mine out and boiled it and it seems to expand 0.16 inches. Is it possible that it just gets weak and doesn't completely seal so not all oil is going through the cooler? I'm trying to decide if it is worth it to try to replace it. I'm getting hotter oil than usual and I've checked everything else anyone has suggested (oil flow, blocked cooler, timing, blowby, etc.). Everything has been fine for 440 hours, so something has clearly changed.
Thanks!
Paul A. Fisher
RV-7A N18PF
- The Matronics LycomingEngines-List Email Forum -
http://www.matronics.com/Navigator?LycomingEngines-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List All times are GMT - 8 Hours
