AAE vhf antenna
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
stephenbehn(at)bigpond.co
PostPosted: Fri May 09, 2014 12:09 am    Post subject: AAE vhf antenna Reply with quote
Hi Everyone,
I am thinking about fitting AAE com and transducer antenna in my lightning kit 69. its a slow build kit Smile I would appreciate any imput as to positioning the antennas and performance in the lightning, photos?
http://www.advancedaircraft.com/
Thanks Cheers
Steve Behn
Australia
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
esn14gp(at)yahoo.com
PostPosted: Fri May 09, 2014 2:12 am    Post subject: AAE vhf antenna Reply with quote
Hi Steve.
While I am currently building a Lightning, I have previously built and fly a Lancair ES.  I used AAE antennae for 2 COMs and the Transponder.  This was despite advice fro other Lancar builders not to do it.
Well, I have since added a Comant belly antenna for COM1 and a traditional blade on the belly for the transponder. I still have COM2 in the tail with the AAE. There is a noticeable decrease in performance with the AAE, both in the COM and the transponder.
Belly antenna going in the Lighting... ground planes in.
Good luck!
Gordon
On Friday, May 9, 2014 4:09 AM, Stephen Behn <stephenbehn(at)bigpond.com> wrote:
Hi Everyone,
Thanks Cheers
Steve Behn
Australia
= the many List utilities such as List
sttwig
PostPosted: Fri May 09, 2014 8:23 am    Post subject: AAE vhf antenna Reply with quote
Steve,
I used three of them in my Lightning. The comm antenna and two of the small ones, one for the transponder and the other for ADS-B (maybe you don't have that in Australia). I mounted them all with sticky back velcro behind the rear bulk head per Mark at Lightning. The comm antenna needs to be as near vertical as possible and will curve around inside of the fuselage. I mounted one of the small ones on the opposite side of the fuselage and can't remember where I put the third one, but it is in the same vicinity, taking into consideration the instructions for proximity to avoid interference. They all work as advertised, although the comm antenna seems to be a bit directional on the ground. I always hear the tower, but occasionally don't hear other aircraft depending on which way I'm pointed. While in the air, there is no problem with the comm antenna being directional.
Steve Sundquist
Kit #48, also a slow build, in the air for 6 months now.
On 5/9/2014 1:09 AM, Stephen Behn wrote:
Hi Everyone,
Thanks Cheers
Steve Behn
Australia
This email is free from viruses and malware because avast! Antivirus protection is active. [quote][b]
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
