Induction leaks where and how did you find them
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List
recapen(at)earthlink.net
PostPosted: Tue May 27, 2014 10:39 am    Post subject: Induction leaks where and how did you find them Reply with quote
Carl,
Good question - I ran a bunch of tests as I am trying to flow balance my fuel injection system. One of the tests was to run at different manifold pressures 25" and 15" and look for a consistent temp change across all cylinders....my #1 didn't change like the others...the remaining text points to a leak in the inconsistent cylinder.
The temps are well below the danger zone - but you can easily see the difference in the graphs between high and low power settings.
Ralph
- The Matronics LycomingEngines-List Email Forum -
http://www.matronics.com/Navigator?LycomingEngines-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List All times are GMT - 8 Hours
