Max time on engine
BobbyPaulk(at)comcast.net
PostPosted: Mon Jun 02, 2014 12:19 pm    Post subject: Max time on engine Reply with quote
Guys
Has anyone compiled a list of the owners of the Jabiru 3300 that have made it to top and overhaul hours.
I would be very interested in a list or database of 3300 engines with 500 or more hours by serial number if possible.
Not necessarily individual ser. numbers but according to the following table -
0 - 960 Solid Lifters
961 - 1683 w/ High leak Hydraulic Lifters
1684 - 2538 w/ Slow leak hydraulic lifters
2539 - Current
My engine is in the 961 to 1683 Serial numbers and has 214 hrs and running good. Temps on #5 & 6 cylinders get up to 325 ~ 330 CHT and I have to change throttle settings to get them under 300 deg. I spent many hours re-jetting the carb. and modifing the Ram Air inlets. I am hoping to get many more hours of Maintenance free time if that is possible.
I suspect the slow leak lifters are causing a lot of engines to come up very short on time for a top overhaul.
I know of at least one that only made it to 107 hrs. The rings were stuck solid in the ring grooves on all cylinders, valves were carboned up and the head to cylinder joints were leaking badly. This engine was run a little hot on break in but has been under 300 deg. CHT since.
I think we owners of these engines are doing the Beta testing for Jabiru.
I would like to hear some good news about engines that have made it over 500 to 600 hrs with no problems.
Are the engines in Jabiru Aircraft having the same problems we are having on other experimentals??
Is there a site where we could post hours and S. N.'s for comparison??
Bobby ( age 76 )
Zodiac 601 XL "B"
Jabiru 3300 S/N 1141
Sensenich 64" x 51" Prop
Bing Carb 260 Main & 290 Needle Jet
Status - Flying 214 hrs.
n5pb(at)aol.com
PostPosted: Mon Jun 02, 2014 2:06 pm    Post subject: Max time on engine Reply with quote
Bobby,
Ive got a ways to go before I reach 1000 hours for the top overhaul.
However, for your info,I've got 225 hours on my engine 3300 (in a Lightning experimental); Engine S/N 1321.
My average CHTs are around 265 and my average EGTs are around: 1285
Density altitude is around 3000' and RPM is approx 2850
I live in Florida and it took a while to figure out the correct jets. I am using a 250 main jet and 283 needle jet. The plane is flying well.
Llike you, I would like to know how these engines are performing beyond 500, 1000 1500 hours.
Bear
N82PB
ftyoder(at)yoderbuilt.com
PostPosted: Mon Jun 02, 2014 2:58 pm    Post subject: Max time on engine Reply with quote
I have S/N 346 in a Thorp T-211 with almost 500 hours. Just had to lap #1 exhaust valve and the CHTs are <290 deg.
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of n5pb(at)aol.com
Sent: Monday, June 02, 2014 3:06 PM
To: jabiruengine-list(at)matronics.com
Subject: Re: Max time on engine
Bobby,
Bear
N82PB
-----Original Message-----
To: Server, JabiruEngine-List Digest <jabiruengine-list(at)matronics.com>
Sent: Mon, Jun 2, 2014 4:19 pm
Subject: Max time on engine
Guys
2539 - Current
Bobby ( age 76 )
Zodiac 601 XL "B"
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
tp://forums.matronics.com
ist">http://www.matronics.com/Navigator?JabiruEngine-List
ics.com
.matronics.com/contribution
This email is free from viruses and malware because avast! Antivirus protection is active. [quote][b]
zeprep251(at)aol.com
PostPosted: Mon Jun 02, 2014 5:26 pm    Post subject: Max time on engine Reply with quote
Have 875hrs on 2200#1295. It's in a Kolb MK-3 cyl hd 260* exh 1400* Sensenich wood prop. So far so good. G. Aman
On Jun 2, 2014, at 6:58 PM, "Tim Yoder" <ftyoder(at)yoderbuilt.com (ftyoder(at)yoderbuilt.com)> wrote:
[quote] I have S/N 346 in a Thorp T-211 with almost 500 hours. Just had to lap #1 exhaust valve and the CHTs are <290 deg.
From: owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com) [mailto:owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com)] On Behalf Of n5pb(at)aol.com (n5pb(at)aol.com)
To: jabiruengine-list(at)matronics.com (jabiruengine-list(at)matronics.com)
Bobby,
Bear
N82PB
From: BobbyPaulk <BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)>
To: Server, JabiruEngine-List Digest <jabiruengine-list(at)matronics.com (jabiruengine-list(at)matronics.com)>
Guys
2539 - Current
Bobby ( age 76 )
Zodiac 601 XL "B"
ics.com
gilles.thesee(at)free.fr
PostPosted: Tue Jun 03, 2014 3:28 am    Post subject: Max time on engine Reply with quote
You mean, "*already* had to lap #1 exhaust valve" ?
Best regards,
Gilles
http://contrails.free.fr
UK Clive
PostPosted: Tue Jun 03, 2014 3:38 am    Post subject: Max time on engine Reply with quote
I have #1460, 70 hrs.
Currently completely stripped to investigate low oil pressure when warm. Can clearly see where the internal leakage has been.
New bigger through bolts from Camit are being fitted with great care on the sealing we hope to have it performing well before long.
Other mods with Camit supplied parts will be published with pictures when we are finished.
Regards Clive
Esqual VM1 in UK
On 2 Jun 2014, at 23:58, "Tim Yoder" <ftyoder(at)yoderbuilt.com (ftyoder(at)yoderbuilt.com)> wrote:
Bobby,
Bear
N82PB
Guys
2539 - Current
Bobby ( age 76 )
Zodiac 601 XL "B"
ics.com
PostPosted: Tue Jun 03, 2014 4:37 am    Post subject: Max time on engine Reply with quote
Correct, it failed the annual compression check.
barnett6088(at)msn.com
PostPosted: Tue Jun 03, 2014 9:40 am    Post subject: Max time on engine Reply with quote
My 3300 SN 33A2374 has 230 hours on it, runs good doesn't burn a noticeable amount of oil like 8 oz. in 25 hours.  Compressions good.  Cylinder temps in the 240 to 280 range.  Gary B.  N335AL
Date: Mon, 2 Jun 2014 20:18:18 +0000
Subject: JabiruEngine-List: Max time on engine
Guys
2539 - Current
Bobby  ( age 76 )
Zodiac 601 XL "B"
-List" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
http://forums.matronics.com
rpf(at)wi.rr.com
PostPosted: Tue Jun 03, 2014 12:32 pm    Post subject: Max time on engine Reply with quote
Jabiru 3300 with solid lifters (0-960) and 880 hours on it.  Cruse at about 2800rpm with CHT’s < 280 and EGT’s between 1300 and 1350.
Randy
Zenith 601xl
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of BobbyPaulk(at)comcast.net
Sent: Monday, June 02, 2014 3:18 PM
Guys
2539 - Current
Bobby ( age 76 )
Zodiac 601 XL "B"
