Battery Cable Fitting
N38CW
PostPosted: Sun Aug 31, 2014 1:03 pm    Post subject: Battery Cable Fitting Reply with quote
I am building an RV-8 with the battery installed in the forward baggage compartment. The battery contactor is mounted about 4" from the positive terminal. The simplest and shortest route for the cable would be a straight 4" length between the two. Is this acceptable, or should I take a somewhat indirect route to the contactor so that the cable has a bit of a loop in it?
Bill Settle
RV-8 Fuselage
PostPosted: Sun Aug 31, 2014 1:16 pm    Post subject: Battery Cable Fitting Reply with quote
Use a ~8" length of 4AWG welding cable
with sufficient wire dress to avoid putting
any stress on terminals on either end
of the jumper wire.
Use heavy-wall heat-shrink to provide
vibration support at the terminals but
let the stuff in the middle wave in the
breeze.
http://tinyurl.com/kfqjphg
The above article illustrates M22759 'fat wire'
but if it were my airplane, welding cable is
the material of first choice.
N38CW
PostPosted: Mon Sep 01, 2014 11:45 am    Post subject: Battery Cable Fitting Reply with quote
As always, Thanks!
On Sunday, August 31, 2014 5:17 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
[quote]--> AeroElectric-List message posted by: "N38CW" <billsettle(at)bellsouth.net (billsettle(at)bellsouth.net)>
cable would be a straight 4" length between the two. Is [quote][b]
Bill Settle
RV-8 Fuselage
jluckey(at)pacbell.net
PostPosted: Mon Sep 01, 2014 2:17 pm    Post subject: Battery Cable Fitting Reply with quote
I second Bob's suggestion. Welding Cable is really great stuff. It's tough-as-nails, very flexible, and easy to work with.
-Jeff
On Monday, September 1, 2014 12:54 PM, Bill Settle <billsettle(at)bellsouth.net> wrote:
As always, Thanks!
