Back home from the Homecoming
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
NowackLinden(at)gmx.de
PostPosted: Sat Oct 11, 2014 9:14 am    Post subject: Back home from the Homecoming Reply with quote
Hi Group,
Uli and I returned safely back to Linden, Germany after a 2day`s drive
from SYI to ORD with a detour via the Wright Patterson AFB`s Museum of
the Air Force near Dayton, Ohio.
We had a really good time in SYI and at the Homecoming weekend. Our
thanks go to Barb and Pete, Nick and Dana and, of course, Claire and
Mark for their hospitality. And my thanks to all the others present for
the interesting and inspiring conversations!
And, at last, again my thanks to Nick for the opportunity to fly and
land the new O320 powered Lightning XS under quite windy conditions.
This flight turned out to be a very encouraging if somewhat shaky
experience!
After returning home yesterday ( and after a short sleep after the
night flight) I unwrapped all the parts I had brought home from Arion
and A/C Spruce and got to work again, freshly motivated and equipped.
The new AN7 bolts gave me the chance to fix the GT Propeller to its
flange for the first time. Perfect fit! (Yes, not all the bolts are
tightened!)
I posted a frontal pic of the prop I some time ago, here is a pic
as seen from the backside only. You can see the wide chord of the blade
root (about 6 1/2 "). I assume that the total blade area of my prop is
equal or even larger than the Whirlwind 3blade`s .
Of course I am very curious how it will perform. I have still some
months of work in front of me, and then there is the chore to gather all
the required data and stuff for the initial Permit To Fly, so I don`t
expect to get my D-EGFL flying very soon. We all propably have to wait
til next year for the performance specs.
BTW you can also see the prop flange adapter and the slipring for the
constant speed wires. Also to be seen: my solution for fitting the AN10
oil cooler hoses.
With the prop mounted I could go and position the cowling in its right
place.
The good news: the longer distance from engine to spinner backplate (
60mm, about 2.4"longer than the ULPower390 equipped Lightning we saw in
SYI) saves me from having to make cheeks for my cowling. Yes, the
engine is inside this cowling !
The drawback: the cowling is too short. There is a yellow line on the
pic that shows where it ends, I will have to make extensions, a little
more than an inch long. But since the cowl ends on the joggle this task
will not too difficult, as I can use the fuselage as a mould.
So when all is done, due to its long snout I will own the longest
Lightning built so far!
Gerd
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
n5pb(at)AOL.COM
PostPosted: Sat Oct 11, 2014 10:49 am    Post subject: Back home from the Homecoming Reply with quote
Gerd,
Glad to hear you got back home safe and sound. It was so good to see both of you at this year's fly-in and spend some time talking with you. I especially enjoyed teasing you during the Giant Jenga Game. You are a good sport! Of course, a big congrats goes out to Uli for winning the game!
Thank you too for bringing a little "flavor" of Germany with you. After a long day, it was nice to quench our thirsts.
Yes, the whole Lightning Jabiru team did a great job hosting the fly-in. It's great to have an annual fly-in where we can meet other builders/owners and, perhaps, get new ideas from then and also a venue to have discussions with the factory.
I'm hoping your Lightning build continues to go well.
Aufwiedershen!
Paul
N82PB
dwwilt
PostPosted: Sat Oct 11, 2014 11:57 am    Post subject: Back home from the Homecoming Reply with quote
Gerd and Uli,
It was so very nice to finally meet you both at the Lightning Homecoming. I truly enjoyed talking and visiting with you both. The annual Homecoming really was a very successful event. Keep the pictures and updates coming. I will surely use them in the next newsletter. The next one should come out in early to mid November.
Dennis W. Wilt
N616DW (Arion Lightning S/N 132)
Dennis
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
