Standard ULPower muffler problem
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
NowackLinden(at)gmx.de
PostPosted: Thu Oct 30, 2014 12:52 am    Post subject: Standard ULPower muffler problem Reply with quote
Group,
if you plan to build a Lightning with a ULpower 6cyl. engine and an exhaust muffler ( yes, some of us live in noise sensitive regoins of the world and have to have them! ) you should be aware that the standard muffler`s exhaust tube and its heat shield does not quite clear the newly designed engine mount that is now sold as the standard mount for ULPower engines. The muffler fits fine - although you should  mount it on the 6 exhaust tubes and also put  the heater on first because there  won`t be  enough room once you have the engine fixed -  but as stated abv. the heat shield contacts a mount tube-see pic!
My solution: I got a modified muffler from ULPower with the exhaust tube welded on a bit  to left and forward, now all is good. See next pic.
Maybe in the future a Lightning modified muffler will be available, or maybe they can weld one for you as they did for me, for a  little extra fee.
Another solution: ULPower offers a muffler without the final exhaust tube , so you can look for  somebody who welds it on at the right spot.
In all other regards the new 10" eng mount is a success,  it clears all engine parts and I was able to accommodate all on the firewall and between FW and engine with no major hassle - except after I had closed  all the holes in the FW and fixed  all the wires and tubes and cables my hands looked as if I had strangled three cats!
Gerd,   Kit 162,  D-EGFL
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
