RS422 - RS232
jimbean6(at)optimum.net
PostPosted: Mon Nov 10, 2014 4:10 pm    Post subject: RS422 - RS232 Reply with quote
In starting to think about ADS-B one way to get out only would be a
Mode-S transponder hooked to the existing Garmin 432W. The 432 speaks
RS232 and the transponder slide in replacement speaks RS422. There are
converters available for under 20 bucks. Is it that simple?
Jim Bean
PostPosted: Mon Nov 10, 2014 5:01 pm    Post subject: RS422 - RS232 Reply with quote
speaks RS232 and the transponder slide in replacement speaks RS422.
There are converters available for under 20 bucks. Is it that simple?
Yeah pretty simple. I used to build them for
some applications in Beech's Targets Division.
Your best bet is just to buy one. See:
http://tinyurl.com/ly5hb9q
PostPosted: Mon Nov 10, 2014 5:07 pm    Post subject: RS422 - RS232 Reply with quote
--> AeroElectric-List message posted by: James Bean <jimbean6(at)optimum.net>
In starting to think about ADS-B one way to get out only would be a Mode-S transponder hooked to the existing Garmin 432W. The 432 speaks RS232 and the transponder slide in replacement speaks RS422. There are converters available for under 20 bucks. Is it that simple?
If you want to build on, here's a schematic.
Bob . . . [quote][b]
PostPosted: Tue Nov 11, 2014 8:02 am    Post subject: Re: RS422 - RS232 Reply with quote
It is my understanding that a mode S transponder must have the EXTENDED SQUITTER feature to be ADS-B compliant in 2020. The data contained in extended squitter transmissions tells the ground station what ADS-B hardware is installed in the aircraft. If the hardware does not meet government regulations, the ground station will not transmit traffic and weather back to the aircraft after 2020. And using hardware that is not certified might be in violation of FARs. An avionics shop like Steinair should be consulted before spending time and money.
Joe
Joe Gores
henry(at)pericynthion.org
PostPosted: Tue Nov 11, 2014 12:46 pm    Post subject: RS422 - RS232 Reply with quote
That will convert the logic levels (physical layer) but are the protocols known to be compatible? i.e. does the 432W (I didn't realize there was such a thing) send messages in a format that the transponder can understand, even after converting to RS-232?
Henry
On Tue, Nov 11, 2014 at 1:06 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] At 18:09 2014-11-10, you wrote:
--> AeroElectric-List message posted by: James Bean <jimbean6(at)optimum.net (jimbean6(at)optimum.net)>
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
PostPosted: Tue Nov 11, 2014 6:37 pm    Post subject: RS422 - RS232 Reply with quote
232/422/etc ARE electrical/handshake standards . . . and
do not describe data formats.
http://tinyurl.com/buupe
http://tinyurl.com/2twp68
Most aviation serial data exchanges are at
9600 bits/sec, 8 bit word, no parity, 1
stop bit. This data framing is independent
of the conduit carrying the data. 422 is
often used as an "extender" for 232. 232
is not suited for long runs between devices
that might have large differences in ground
potential (ground loop noises). 422 is twisted
pair with much greater noise immunity. We had
some equipment at Hawker/Beech where I converted
232 to 422 and back to 232 some 100 feet away.
Somewhere in my software cookie jar, I have a
routine that looks at the serial data input port
and measures the bit rate. You can squirt anything
from 600 to 19,600 bits per second at it . . . and
it will sync up and go to work. You still have to
do the 8,N,1 thingy but bit rate is optional.
You'll need to consult the installation manuals
for the systems you wish to link . . . odds are
they both speak 9600,8,N,1 but it's a good thing
to check.
donjohnston
PostPosted: Wed Nov 12, 2014 7:37 am    Post subject: Re: RS422 - RS232 Reply with quote
Arrrgh!
Grand Rapids charged me $200 for an RS-422 to RS-232 adapter. Embarassed
PostPosted: Wed Nov 12, 2014 4:32 pm    Post subject: RS422 - RS232 Reply with quote
This seems to have generated some interest so I will expand.
I presently have a Becker atc4401 Mode A/C thansponder and a Garmin 430W
gps/com/nav.
Don't know where 432W came from, sorry for the confusion.
The Becker bxp6401 Mode S ia a slide in replacement with an extra
connector for the Mode S connection.
It is not in a rack so "slide in" means the same pin-outs on the main
connector.
There is also a dongle that is programmed to provide the Mode S address.
It definitely has extended squitter. It also does Mode A and C.
Accord in to Garmin the 430W will operate with any capable Mode S
transponder.
So this seems to be a viable solution, particularly if one already has
the Becker Mode A/C.
Jim Bean
Jim Bean
peter(at)sportingaero.com
PostPosted: Sat Nov 15, 2014 3:28 am    Post subject: RS422 - RS232 Reply with quote
So the important question is what data format does the Becker require?
One aspect is the protocol (in this case RS422), but equally important
is what that input data represents. If it requires NMEA sentences you
are probably in luck as the 430 almost certainly will output most of the
common sentences, such as RMC and RMB (both required for full extended
squitter). If some other data format is required it will probably get
all too difficult.
Look carefully at the 6401 specification as somewhere it will state the
required input data format.
Peter
430W gps/com/nav.
connector.
transponder.
Jim Bean
simple?
Jim Bean
PostPosted: Sat Nov 15, 2014 3:53 am    Post subject: RS422 - RS232 Reply with quote
I found the installation manual on the web,
http://www.becker-avionics.com/download/Manuals%20and%20Specifications/BXP%206400_Family/BXP6401-X-(XX)%20Installation%20and%20Operation%20Issue3-ads-b.pdf
<http://www.becker-avionics.com/download/Manuals%20and%20Specifications/BXP%206400_Family/BXP6401-X-%28XX%29%20Installation%20and%20Operation%20Issue3-ads-b.pdf>
The way I read it, a 430 hooked up by 232 will be adequate, interesting
that a 430 & 530 are listed as non-certified GPS receivers!
There is also a reference to the data interface document.
Peter
On 15/11/2014 11:27, Peter Pengilly wrote:
<peter(at)sportingaero.com>
the common sentences, such as RMC and RMB (both required for full
extended squitter). If some other data format is required it will
probably get all too difficult.
the required input data format.
Peter
> 430W gps/com/nav.
> connector.
> transponder.
> has the Becker Mode A/C.
> Jim Bean
> simple?
> Jim Bean
PostPosted: Sat Nov 15, 2014 6:58 am    Post subject: RS422 - RS232 Reply with quote
Peter, thanks for posting the link. I've added this
document to the installation data library
on aeroelectric.com . . .
phudes(at)ix.netcom.com
PostPosted: Sat Nov 15, 2014 9:14 am    Post subject: RS422 - RS232 Reply with quote
I think that is because you need Waas receivers ( 430W & 530W).
Pete
http://www.becker-avionics.com/download/Manuals%20and%20Specifications/BXP%206400_Family/BXP6401-X-(XX)%20Installation%20and%20Operation%20Issue3-ads-b.pdf <http://www.becker-avionics.com/download/Manuals%20and%20Specifications/BXP%206400_Family/BXP6401-X-%28XX%29%20Installation%20and%20Operation%20Issue3-ads-b.pdf>
The way I read it, a 430 hooked up by 232 will be adequate, interesting that a 430 & 530 are listed as non-certified GPS receivers!
Peter
> So the important question is what data format does the Becker require? One aspect is the protocol (in this case RS422), but equally important is what that input data represents. If it requires NMEA sentences you are probably in luck as the 430 almost certainly will output most of the common sentences, such as RMC and RMB (both required for full extended squitter). If some other data format is required it will probably get all too difficult.
> Look carefully at the 6401 specification as somewhere it will state the required input data format.
> Peter
>> I presently have a Becker atc4401 Mode A/C thansponder and a Garmin 430W gps/com/nav.
>> The Becker bxp6401 Mode S ia a slide in replacement with an extra connector for the Mode S connection.
>> It is not in a rack so "slide in" means the same pin-outs on the main connector.
>> Accord in to Garmin the 430W will operate with any capable Mode S transponder.
>> So this seems to be a viable solution, particularly if one already has the Becker Mode A/C.
>> Jim Bean
>> Jim Bean
