A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL
gareywittich2000(at)yahoo
PostPosted: Tue Jun 27, 2006 9:22 am    Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL Reply with quote
THIS IS NOT "SPAM", but comes from 600+ hours of
research I did while building my RV-8A.
SAVE YOURSELF hundreds of hours of research time that
can be better spent "building your project", by using
the comprehensive
"Guide to Painting & Corrosion Control of Aluminum and
Composite Aircraft" (In 3rd printing)
Contains 66 pages of the latest, practical information
- summarized and gathered from MIL Standards, Paint
Shops, Builders like you (what worked or didn't),
Airframe Mfgs, etc. Covers products from - PP&G,
Dupont, Sherwin W'ms, Sterling, Poly Fiber, Deft,
Randolph Paints, PRC De Soto, US Paints, Aircraft
Finishing Systems, 3M, etc.
Some of the Topics covered in the 30 Sections are:
* Aircraft Paints vs Auto Paints
* Corrosion Control
* Primers for Fiberglass & Steel
* Prep Methods for Painting - Fiberglass,
Aluminum and Steel
* Epoxy Primers for Aluminum - MIL & Commercial,
Solvent & Water
Reducible
* Wash Primers & Self Etching Primers
* Other Primers - Zinc Chromate, Zinc Oxide,
Enamel
* Paint Types : MIL & Non MIL Polyurethanes,
Enamel
* Acid Etch / Conversion Coatings (Alodine)
* Spray Guns - selecting, adjusting, using &
painting problems
* Brushes / Rollers used with Primers & Paints
* Selecting a Paint Shop
* 3M Cleaning Pads & Cleaners
* Paint Booths and their Construction
* References - MIL Standard & Tech Orders
* Directory of Aircraft Paint Mfgs, Distributors
- phone numbers, E-
Mail addresses, Application Notes
YOUR AIRPLANE is judged by it's "Paint Job", so have
the latest "Information" in order to make good
decisions. Contains "Do's" and "Don'ts" that save you
time, $$$ and frustration.
Send check for $26 (includes postage within US) to:
Garey Wittich
58 Village Pkwy
Santa Monica, CA. 90405
