Alternator
BobbyPaulk(at)comcast.net
PostPosted: Thu Dec 11, 2014 5:55 pm    Post subject: Alternator Reply with quote
Rob,
Thanks for checking out the alternator for me.
I had not had time to do so. I just saw in the overhaul manual that it needed to be replaced. I was going to check with Pete before I did anything.
So now I will not have to do that.
Thanks.
Does anyone have a used 101 tooth flywheel with or without magnets. My starter ring gear is good so if the 99 tooth flywheel is the same I can replace the ring gear.
I will be sending a list of parts to Pete at Jabiru USA for pricing in a day or two.
This list is saving me money.
Thank you all for your input.
Bobby
