406 ELT
andrew(at)entro.com
PostPosted: Sun Dec 14, 2014 4:46 pm    Post subject: 406 ELT Reply with quote
Hi
I'm looking at replacing the 121.5 MHz ELT with a 406 MHz ELT. Is
there a recommended unit that replaces the old one with the least
amount of work and money.
Andrew
teamgrumman(at)yahoo.com
PostPosted: Sun Dec 14, 2014 6:13 pm    Post subject: 406 ELT Reply with quote
I installed an ACK 406 in a customer’s plane. It’s a decent ELT. A five on a 1 to 10 scale. (5/10)
The worst part is:
1) Running the wires to the back of the plane
2) The remote switch needs a battery.
3) The one I installed required a separate buzzer (included)
4) The antenna is bent and so it won’t go through the dorsal like it should
(I bent the antenna so it would go through the dorsal. Why it isn’t straight is beyond me.)
5) The connector at the ELT needs to be ‘assembled’ since it is designed for a separate GPS
(This is a major pain-in-the-ass.)
http://www.ackavionics.com/pdf/E-04_REV_1.7_SINGLE_PAGE_REDUCED.pdf
Gary
On Dec 14, 2014, at 4:46 PM, Andrew Kuzyk <andrew(at)entro.com> wrote:
Hi
Andrew
