Holes in the Landing Gear Mounts
trigo(at)mail.telepac.pt
PostPosted: Sat Dec 20, 2014 9:15 am    Post subject: Holes in the Landing Gear Mounts Reply with quote
Guys
The WD-102- L & R Landing Gear Mounts have, each of them, 4 holes in the horizontal part, the ones which must be final-drilled #12 according to step 4 (on figure 4) of page 28-16 of the Manual (Section 28 : Fwd Ribs, Bhds & Bottom Skins), which doesn’t seem to be used for anything.
Does anybody know what are these 4 holes for?
I ask because I didn’t find the answer in the Manual, though I’m tempted to use those holes to install an electric connector bus for the bunch of wires which come from the Stick grip …
Carlos
Este email está livre de vírus e malware porque a proteção avast! Antivirus está ativa. [quote][b]
Rocketman1988
PostPosted: Sat Dec 20, 2014 12:35 pm    Post subject: Re: Holes in the Landing Gear Mounts Reply with quote
Those holes are for the Mid Seat Rail Supports that you assembled in step 1 and 2.
There are also several threads that identify the fact that the plans do not tell you when to install these supports, only that they should be left out in order to drill and ream the gear leg mounting hole...
flying-nut(at)cfl.rr.com
PostPosted: Sat Dec 20, 2014 12:56 pm    Post subject: Holes in the Landing Gear Mounts Reply with quote
I got so frustrated trying to use the 4 bolts/nuts to attach those
'spacers' that I created a plate with three nutplates to go on one side
of the web (that you can't see) ..... and the bolt/nut to go on the
other side of the web. Because I could.
Linn
http://forums.matronics.com/viewtopic.php?p=435945#435945
Checked by AVG - www.avg.com
larkrv10(at)gmail.com
PostPosted: Sun Dec 21, 2014 6:38 pm    Post subject: Holes in the Landing Gear Mounts Reply with quote
Hey Linn, I had to bring in the reserves to help get those nuts/washers on (my wife and her little hands).  Heading your way at New Years, so I need to come for an inspection (again)  Wink
Rick
#40956
Southampton, Ont
On Sat, Dec 20, 2014 at 3:53 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
[quote]--> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
I got so frustrated trying to use the 4 bolts/nuts to attach those 'spacers' that I created a plate with three nutplates to go on one side of the web (that you can't see) ..... and the bolt/nut to go on the other side of the web. Because I could.
Linn
--> RV10-List message posted by: "Rocketman1988" <Rocketman(at)etczone.com (Rocketman(at)etczone.com)>
br> fts!)
r> > /www.aeroelectric.com" target="_blank">www.aeroelectric.com
w.buildersbooks.com" target="_blank">www.buildersbooks.com
p.com" target="_blank">www.homebuilthelp.com
e.com" target="_blank">www.mypilotstore.com
" target="_blank">www.mrrace.com
          -Matt Dralle, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
FORUMS -
PostPosted: Sun Dec 21, 2014 6:46 pm    Post subject: Holes in the Landing Gear Mounts Reply with quote
Hi Rick!
Just give me a call .....
Merry Christmas!!
Linn
On 12/21/2014 9:35 PM, Rick Lark wrote:
[quote] Hey Linn, I had to bring in the reserves to help get those nuts/washers on (my wife and her little hands).  Heading your way at New Years, so I need to come for an inspection (again)  Wink
Rick
#40956
Southampton, Ont
Linn
br> fts!)
FORUMS -
12/21/14 [b]
bob88
PostPosted: Sun Dec 28, 2014 4:33 pm    Post subject: Re: Holes in the Landing Gear Mounts Reply with quote
Another problem with those holes...I can't get them to line up with the holes in the seat rail and seat bottom. The mid seat rail supports are bolted into the landing gear mount (after much frustration) but they are half a hole too far forward. Can't move them back because the rear flanges on the mid seat rail supports are right up against the landing gear mount and it would be necessary to elongate the holes in the bottom of the mid seat rail support in any case. Anyone else with this problem? Solutions?
