CHT sensor Installation
AirEupora
PostPosted: Sun Jan 18, 2015 8:21 am    Post subject: CHT sensor Installation Reply with quote
I just downloaded AVDALSR085-1 and noticed that it calls out a 5/32 screw. I'm not sure, but I think it should be a 6/32 screw. Unless there are 5/32 screws down under! Paragraph 3.5
I'm start this mod this morning and will install 8/32 screws as that is what I have on the shelf.
Has anybody else completed this mod?
europa471
PostPosted: Sun Jan 18, 2015 3:13 pm    Post subject: CHT sensor Installation Reply with quote
Rick
The CHT leads that Camit supply have 8/32" thread.
See:
http://camitaeroengines.net/collections/ancillary-parts/products/engine-cht-sensor
Lance Sandford in OZ
http://forums.matronics.com/viewtopic.php?p=437200#437200
zipper
PostPosted: Sun Jan 18, 2015 5:10 pm    Post subject: CHT sensor Installation Reply with quote
i used 8-32 and think 6-32 would be too flimsy.
Additionally, instead of crimping on a new ring terminal, I just punched a hole in the fat part of the spark plug ring sensor and trimmed the excess off to a round shape and screwed that down. Worked perfectly. I did one side a few weeks before the other and in flying with the mixed CHT setup saw no difference in readings from one side to the other.
George Andre, 3300 #987, St Louis Missouri.
On Sunday, January 18, 2015 5:18 PM, Lance Sandford <lsandford(at)westnet.com.au> wrote:
--> JabiruEngine-List message posted by: Lance Sandford <lsandford(at)westnet.com.au (lsandford(at)westnet.com.au)>
Rick
See:
[quote] --> JabiruEngine-List message posted by: "AirEupora" <AirEupora(at)sbcglobal.net (AirEupora(at)sbcglobal.net)>
barnett6088(at)msn.com
PostPosted: Tue Jan 20, 2015 1:11 pm    Post subject: CHT sensor Installation Reply with quote
George
I tested one cylinder with both the spark plug thermocouple and one attached to the cylinder.  In most operations the cylinder thermocouple was 6 to 8 degrees F warmer than the spark plug sensor. Gary
Sent from my iPad
On Jan 18, 2015, at 5:10 PM, George Andre <glandre(at)sbcglobal.net (glandre(at)sbcglobal.net)> wrote:
[quote]i used 8-32 and think 6-32 would be too flimsy.
On Sunday, January 18, 2015 5:18 PM, Lance Sandford <lsandford(at)westnet.com.au (lsandford(at)westnet.com.au)> wrote:
Rick
See:
www.aeroelectric.com >www.buildersbooks.com uilthelp.com otstore.com matronics.com/contribution =================================== st">http://www.matronics.com/Navigator?JabiruEngine-List =================================== cs.com =================================== [/b]
