tkreiner
Posted: Fri Feb 06, 2015 1:02 pm Post subject: Cub Fuel Tank from project |
A SE TX project plane is available, and for the right $$$, I might be interested in getting it. Project has ribs, two sets of spars, steel tube fuse, and a box full of extra tubing, etc. The tank is a new, unused J3 Cub tank, and it still has stickers on it...
So, the question is: is anyone using a J3 Cub fuel tank in their Piet? If so, please let me know your experience, i.e., not enough fuel, just right, etc., also, let me know whether it's a drop in, or requires a lot of work to use.
Since I have a fuse, the steel tube fuse might become available.
| - The Matronics Pietenpol-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pietenpol-List |
_________________ Tom Kreiner |
bencharvet(at)gmail.com Guest
Posted: Fri Feb 06, 2015 1:55 pm Post subject: Cub Fuel Tank from project |
I'm using a J3 tank. It was an easy fit amd 12 gallons is more than i need
Tom Kreiner
http://forums.matronics.com/viewtopic.php?p=438121#438121
Ray Krause
Posted: Fri Feb 06, 2015 7:07 pm Post subject: Cub Fuel Tank from project |
I'm using one in the Sky Scout, but had to cut a triangle piece off the bottom rear area, now it holds only 10 gals. Easy installation.
Quote: | On Feb 6, 2015, at 1:55 PM, Ben Charvet <bencharvet(at)gmail.com> wrote:
> Thanks,
> Tom Kreiner
Description: |
Filesize: |
37.45 KB |
Viewed: |
2817 Time(s) |
Description: |
Filesize: |
32.22 KB |
Viewed: |
2817 Time(s) |
jack(at)textors.com Guest
Posted: Sat Feb 07, 2015 4:26 am Post subject: Cub Fuel Tank from project |
Tom it fits well. I'm putting a sump in mine so it hopefully will allow draining in the three point attitude...
Jack Textor
Quote: | On Feb 6, 2015, at 3:02 PM, "tkreiner" <tkreiner(at)gmail.com> wrote:
Tom Kreiner
TriScout
Posted: Sat Feb 07, 2015 8:07 am Post subject: Re: Cub Fuel Tank from project |
That would be a "penzon" …. penzon the engine you plan on installing. I did not build my GN-1, but had been flying it for 4 yrs now to BBQ's, Bfast, etc, and I'm liking the 12 gal Cub tank w/the A65. Just enough to stretch out and meet people at small aerodromes..
I entertained the thought/logistics of adding a temporary 30 gallon tank to the front seat and try to non-stop from Dallas-Brodhead, but not sure how I would add oil while inflight…just a daydream I suppose..
ler
_________________ KLNC
A65-8
N2308C
Slick 4330's
AN Hardware
Airframe 780TT
W72CK-42 Sensenich
Standard Factory GN-1 |
taildrags
Joined: 29 Dec 2009 Posts: 1682 Location: Medford, OR
Posted: Sun Feb 08, 2015 5:48 pm Post subject: Re: Cub Fuel Tank from project |
Tom; have you decided about purchasing that project? If you acquire the project and want to sell the steel tube fuselage, as they say in the upper midwest, "I'll buy it off ya" and have a friend who can pick it up.
Regarding fuel capacity, Scout carries 16 gallons in the nose and has a Stromberg carb, so the geometry -not the tank capacity- determines the fuel flow and endurance. I have found, by experience, that the bottom 3 or 4 gallons are unusable in the 3-point attitude and are either "cruise reserve" for an emergency in level flight only, or are nose ballast. My airplane has a cruise range of about 2 hours, maybe 2-1/2, but that's about as long as I want to sit in the airplane at a single stretch anyway and I can generally plan on finding an airport or strip within 100-120 miles of my fueling point in most areas. Nevada and the California desert are exceptions, and headwinds change everything. The point is, if your Cub tank holds 12 gallons, you may want to do a fuel flow test the way Tony Bingelis describes it, and do your flight planning accordingly.
_________________ Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power, 72x36 Culver prop |
steven.d.dortch(at)gmail. Guest
Posted: Sun Feb 08, 2015 8:38 pm Post subject: Cub Fuel Tank from project |
Oscar, thanks for the heads up on unusable fuel. I poked around the Piper cub sites and their general consensus is a 12 gallon tank with 10 useable.
Since my solution to putting two planes in a one plane hangar involves "kneeling" my Piet on it's nose, I am considering turning the nose tank around. Currently the gas cap is in the front 1/3. By turning it around, the cap would be in the rear 1/3rd.
It would mean slightly less fuel in a 3 point attitude but I could leave more in it before putting it in storage. Just a weekend project.
But it will not happen until I fly the thing. That is not required for flight. If I have to drain fuel before I put it up, so be it.
Blue Skies,
Steve D.
On Sun, Feb 8, 2015 at 7:48 PM, taildrags <taildrags(at)hotmail.com (taildrags(at)hotmail.com)> wrote:
Quote: | --> Pietenpol-List message posted by: "taildrags" <taildrags(at)hotmail.com (taildrags(at)hotmail.com)>
Oscar Zuniga
Medford, OR
A75 power
http://forums.matronics.com/viewtopic.php?p=438173#438173
br> enpol-List" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List
Blue Skies,
Steve D
taildrags
Posted: Mon Feb 09, 2015 9:39 pm Post subject: Re: Cub Fuel Tank from project |
Steve;
I'm glad to see that you've put things in proper perspective by recognizing that your fuel situation may require some adjustment, but you may be able to put off the adjustment until after you've begun test flights. Just don't get complacent... recognize the fuel system's possible limitations and respect those. Keep the fuel topped off or at least within the upper 3/4 of the tank until you're comfortable flying it in all regimes. Go through any list of experimental aircraft accidents and incidents and fuel problems will be in the top couple of causes. Read and heed.
What I would probably do after that is fly the airplane in the pattern on a nice day, practicing takeoffs and landings to improve my skill and comfort at the controls as the fuel level got down into the bottom part of the tank. The rest is just my personal testing regime and is based on my comfort level with my plane, at my home field, under controlled conditions. There is no need to fly an actual dead-stick landing when you can simulate flying out of the very last of the tank by putting the tailwheel in a ditch and elevating the nose as you run the engine at a fast idle till it's starved of fuel and sputters to a halt. At that point you can determine how much of your fuel is actually unusable and how much is marginal, and go from there.
Medford, OR
