Tank construction details - XP
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List
scott(at)s-f-x.com
PostPosted: Wed Mar 11, 2015 12:20 am    Post subject: Tank construction details - XP Reply with quote
Hi All
Does anyone have the spec of the construction of the wing tanks on an XP ? I’m replacing the little filler caps and drain plugs and the composite people need to know what layers are in there in order to draw up the plans to get it past the LAA (UK home-builder’s governing body). I have the manuals but they seem to be for the fuselage tank version.
Scott MacIntyre
- The Matronics Pulsar-List Email Forum -
http://www.matronics.com/Navigator?Pulsar-List
mjb777
PostPosted: Wed Mar 11, 2015 12:40 am    Post subject: Re: Tank construction details - XP Reply with quote
What's your email address scott?
I have the original AD wing tank supplement in PDF I can email to you.
Matt.
Pulsar 1 TD Kit.
Captain B777.
Licenced Aircraft Maintenance Engineer.
briana(at)xtra.co.nz
PostPosted: Wed Mar 11, 2015 10:38 am    Post subject: Tank construction details - XP Reply with quote
My XP kit came with the filler neck already bonded into the wing tank moulding and there are no layup details in the manual. There is however a cross section diagram illustrating how it is done.
Basically the top skin seems to be removed to allow the filler neck sit down flush with the outer skin. There is no evidence of a lamination being applied over that, but that might be wise. Then there is the normal micro fillet around the neck, inside the tank, and glass over that. The whole inside is sealed of course [by the builder] with Jeffco 9700.
Brian
XP #456
On 11/03/2015, at 9:19 pm, Scott MacIntyre <scott(at)s-f-x.com (scott(at)s-f-x.com)> wrote:
Hi All
Scott MacIntyre
class="">http://www.matronics.com/Navigator?Pulsar-List
class="">http://forums.matronics.com
class="">http://www.matronics.com/contribution
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List All times are GMT - 8 Hours
