RV-List Digest: 0 Msgs - 03/17/15
dwntzl(at)yahoo.com
PostPosted: Wed Mar 18, 2015 9:46 am    Post subject: RV-List Digest: 0 Msgs - 03/17/15 Reply with quote
Hello fellow RV'rs, Looking for advice, here's my situation \ problem. (I have an RV6, w an 0-320 A2B which was installed rebuilt, modified to 160 HP, during construction about 700 hrs ago). It has been running great, but I have been seeing a couple of small oil leaks, (which have gotten to be quite annoying.) While doing an oil change recently, I discovered one of the top cylinder bolts (small one - not the larger thru bolts) had sheared off. I had not done anything to it whatsoever, nor was there any evidence of looseness or an oil leak in that area, the broken part was just sitting there, I then jiggled the other upper bolts by hand and . . . 2 of them were just finger tight!. Someone (a local A&P) suggested that a good welder could weld a nut to the broken stud and remove it that way - but that sounds way to "scary" to me.
Any advice appreciated. Also . . . is the plane grounded until the repair??
David Wentzell N233DW
dwntzl(at)yahoo.com
On Wednesday, March 18, 2015 3:24 AM, RV-List Digest Server <rv-list(at)matronics.com> wrote:
Today's complete RV-List Digest can also be found in either of the
of the RV-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2015-03-17&Archive=RV
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2015-03-17&Archive=RV
  RV-List Digest Archive
Total Messages Posted Tue 03/17/15: 0
Today's Message Index:
_-========================="http://www.matronics.com/Navigator?RV-List" target="_blank">http://wwbsp; -Matt Dralle, List Admin.
