Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Fri Mar 27, 2015 4:30 pm Post subject: Skyforce GPS |
Hi, All.
Have the standard GPS installation in my Europa, and I am getting a constant timed flash of interference coming through the head set.
Switch the GPS OFF and the flash of interference stops,
Pull the unit out of its housing by about 3 inches with it turned on and the interference has gone,
What is causing this constant timed flash of interference.
1.If I can fix the cause of it,
2.How can I shield the GPS unit from picking this signal up,
As I said pull the unit away from its housing by about 3 " and its gone.
Regards.
Alan
tennant
Posted: Sun Mar 29, 2015 2:19 am Post subject: Re: Skyforce GPS |
Hi Alan,
I suffered from this interference for a long time. It seems to come from the screen on the Skyforce. I tried all sorts of suppression but as the interference is from the screen, direct to the radio, not in the wiring nothing worked.
I eventually increased the suppression on my Becker radio and it disappeared.
Barry
_________________ Barry Tennant
D-EHBT
At EDLM - Germany |
Alan Carter
Posted: Sun Mar 29, 2015 1:53 pm Post subject: Re: Skyforce GPS |
Hi Barry,
from the screen ???
If I hold the unit just a few inches out of its housing the timed screech stops. its like pulse signal, I was thinking in wrapping the case with something radio wave won,t travel through, leads a bit heavy any idea's
Alan
