paulm(at)olypen.com Guest
Posted: Sat Jul 01, 2006 9:35 pm Post subject: Modifing an ND alternator regulator |
Brian,
The ND generic alternator uses a different way of powering the regulator. The 3 diodes you mention are not used (missing from the design) in the ND brand. The regulator gets its power directly from the "B" lead and the connection is part of a bolted stack of connections that are not easy to isolate for the builder.
The MI brand, also popular, as its small and light (for the 50+amp current output) has the 3 diodes you mention and a simple snip of an internal link does the job you suggest (also covered in the Contact! article {Years old BTW}).
Its very easy to modify the regulator to make the alternator 100% external regulation but the resulting modification requires a ground switching external regulator, not the more common positive switching regulator (LR3 for example). Transpo and most other regulator manufacturers have both types and have proven quite reliable in the trucking industry.
It does not seem easy to keep the internal regulator usable because of the way the "B" lead is connected mechanically. Possible but only with some mechanical mods which I would not recommend for most builders. Low cost external regulators are a much better way to go; If one is worried about the concerns, by many, about some failure modes of internal regulators.
The above modification takes around one hour from start of regulator removal to completion and reassembly. No case splitting etc is required. Its very simple to do. The end bells. bearings, and armature are not disturbed. A really neat design for simple repairs etc. This approach does have one fault mode of possible concern as the ground switch in the regulator can short. This is simple to provide for with a relay as it only switches the field not the HI current "B" lead.
This mod is 100% contained within the bolt on regulator module so getting a replacement alternator that fits is much simpler as all you need do is exchange the regulator with your converted one which is a 10 min task.
I am willing (if there is enough interest) to make a brand new PDF showing the details with new pictures etc. It would take a couple of weeks to do as this coming week is Arlington air show where I am a long time volunteer.
For the record I know of NO B&C alternator failure. I have in my possession a failed LR3 regulator that burned up internally (part(s) charred) and did not pop the CB!. I have not heard of any other LR3 failures so that pricey system is very reliable in my opinion. The above (my) suggested approach is around $100 (and up) for a brand new ND alternator Lester #14684, one hour of your time, and a $25 ground switching regulator (no I do not have a part number handy). I am not convinced there is any measurable reliability difference for the extra $600+. The 14684 is rated for 18,000 rpm by the manufacturer.
On the other hand I know of NO Brand New ND alternator (with internal regulator) that failed except for quite a few where there was a crowbar module and a common contactor in the "B" lead. That setup with (out other/different parts etc) has both a theoretical analysis and demonstrated high chance of failing a good alternator from false or intentional tripping. The typical contactor is not designed to break the electrical load of the alternator and the use of a diode across the contactor makes it 5-10 times more likely the result will burn out the alternator that otherwise was good. Also lots of used repaired alternators failing. Repaired is what is done, rebuilt is misleading.
Thus, if you throw out the rebuilt failures and the crow bar/contactor failures, I know of NO failures of the Stock new ND alternator.
The above for data demanders (I am one also)
Paul
PS I only post when my name comes up and I feel its important to comment.
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Sun Jul 02, 2006 5:58 am Post subject: Modifing an ND alternator regulator |
On Jul 2, 2006, at 1:34 AM, Paul Messinger wrote:
| Quote: | Brian,
That is odd. Without the diodes to provide isolation the battery
would be providing power to the regulator even when the engine isn't
running. Remember, most automobiles have the alternator connected to
the battery all the time. This would drain the battery. I would like
to see how they prevent the alternator from killing the battery.
| Quote: | The MI brand, also popular, as its small and light (for the 50+amp
I understand. Sounds like you wrote a good article.
| Quote: | Its very easy to modify the regulator to make the alternator 100%
You might be able to break the path from the B-lead to the field and
then have access to both field terminals. Then you can do what you
want with it. And I agree, I prefer an externally regulated
alternator myself.
| Quote: | It does not seem easy to keep the internal regulator usable because
Never having seen the inside of a ND alternator I knew I was going
out on a bit of a limb. But it might not be that hard. Heck, if you
have people building a whole airframe you have to assume they have
learned how to properly drill a hole and install a bolt in it.
is a 10 min task.
I would certainly like to see it.
Brian Lloyd 361 Catterline Way
brianl at lloyd dot com Folsom, CA 95630
"Five percent of the people think.
Ten percent of the people think they think.
Eighty-five percent of the people would rather die than think."
---Thomas A. Edison
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
brian
Posted: Sun Jul 02, 2006 5:49 pm Post subject: Modifing an ND alternator regulator |
On Jul 2, 2006, at 11:21 AM, Paul Messinger wrote:
<paulm(at)olypen.com>
The isolation is internal to the regulator to prevent high current
drain when the battery is connected and the engine is off. The
"IGN" lead controlls the "B" lead power to the regulator. There is
some current drain which requires an auto to be started every 10-20
days to prevent large battery discharging which is not an issue in
an aircraft. Its worth noting the ND regulator design for this ND
series is 30 years old. The amount of standby drain varies with the
specific regulator but I have seen as much as 90 ma in an auto.
The start of this original failure thread had a comment that the
IGN lead did not turn off the alternator. This tells me the
"rebuilt alternator had a already failed regulator as a good ND
regulator will turn on and off the power when running using the IGN
lead.
I guess I read this a different way. If the regulator has power
applied and there are enough electrons flowing to allow the IGN lead
to control the behavior of the regulator, the regulator is "on" to
some extent. Kind of like most consume electronics that are drawing
power and doing things with their microprocessors even when they are
"off". Just because you turn the switch to "off" doesn't mean it
isn't drawing power and doing something.
I guess this is a clear warning about rebuilt alternators and
associated quality control
As for seperating the field, nothing is impossible but its not
something I would want the average person to do and I see no point
to having an internal regulator with total external control. I have
looked into that and felt it was not for most people to try. Its
hard to describe but the ND mechanical wiring is different from
most alternators and that makes you idea harder to do.
That is certainly a possibility. I have no experience with the ND
alternator.
Go one way or the other(internal or external). There are 100% safe
ways of disconnecting the "B" lead but a just a common contactor is
not a safe way. The only contactor available at a "reasonable"
price rated to open that circuit is the kilovac. Electrical parts
(External to the common contactor) can be added to make the
contactor safe but that is a different issue not included here.
And that issue has already been beaten to death. Having the pass/
switch transistor fail shorted will cause any IR alternator to turn
on hard with no way to turn it off. It seemed to me if we could
control the field excitation externally we could truly turn off the
alternator.
I will now shut up about this. I plan to get a B&C alternator as B&C
already has the mounting and adaptor plates for the Russian radial
engine. I don't plan to use an ND alternator.
Posted: Sun Jul 02, 2006 7:42 pm Post subject: Modifing an ND alternator regulator |
