Hot Cylinder
BobbyPaulk(at)comcast.net
PostPosted: Tue Jun 09, 2015 2:41 pm    Post subject: Hot Cylinder Reply with quote
I removed my carb recently and re-installed it level. Does any one remember which way to tilt the TOP of the carb.
Is it toward the hot cylinder or away from it. I promise to write it down and post it all over my logs.
My #6 cylinder is about 150 degrees hotter than the other EGT's which makes the CHT close to 350.
I had all the CHT's under 300 at a low cruise of 2450.
Bobby ( age 77 )
Zodiac 601 XL "B"
Jabiru 3300 S/N 1141
Sensenich 64" x 51" Prop
Bing Carb 260 Main & 290 Needle Jet
Status - Flying 237 hrs.
sttwig
PostPosted: Tue Jun 09, 2015 3:23 pm    Post subject: Re: Hot Cylinder Reply with quote
The following link answers your question about tipping the carb.
http://usjabiru.com/wp-content/uploads/2015/03/Tuning_the_Bing_Carburetor_on_Jabiru_Aircraft_Engines.pdf
ftyoder(at)yoderbuilt.com
PostPosted: Tue Jun 09, 2015 3:34 pm    Post subject: Hot Cylinder Reply with quote
Per Pete last week, Tilt tilt the BOTTOM of the carb toward the hot side.
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of BobbyPaulk(at)comcast.net
Sent: Tuesday, June 09, 2015 3:41 PM
To: Server, JabiruEngine-List Digest
Subject: Hot Cylinder
Bobby ( age 77 )
Zodiac 601 XL "B"
ist">http://www.matronics.com/Navigator?JabiruEngine-List
ics.com
.matronics.com/contribution
www.avast.com [quote][b]
zman601xl(at)aol.com
PostPosted: Wed Jun 10, 2015 6:11 am    Post subject: Hot Cylinder Reply with quote
Bob,
Pete said to tilt the bottom towards the hot side
    Bob H.
