Tilt
BobbyPaulk(at)comcast.net
PostPosted: Wed Jun 10, 2015 5:43 am    Post subject: Tilt Reply with quote
List
Below is the exact wording (copied and pasted ) from "Tuning the Bing Carburetor on the Jabiru Engine"
"As the flow speeds into the intake manifold it is split left and right by
a symmetrical airfoil called a diffuser. If, for instance, the airflow spirals in a clockwise
movement as it progresses through the carb throat it will pick up fuel at the bottom of
the throat and begin moving the fuel to the left. Before the fuel is evenly spread
through the incoming air stream the flow hits the diffuser and splits left and right. The
result is that the fuel /. Air mixture delivered to the left side (cylinders 2,4,6) has more
fuel in it (richer) than that delivered to the right side (1,3,5). The left side will be leaner
– therefore hotter EGT’s. By rotating the bottom of the carb toward the right (hot side)
you move the fuel pickup toward the right."
I am confused about what they are saying. IF the left side is "richer" and has more fuel in it it should be COOLER.
The left side will NOT be leaner. The last sentence should be correct.
So I tilt the BOTTOM of the Carb toward my hot cylinder #6 and should cool it a bit??
bobby
ftyoder(at)yoderbuilt.com
PostPosted: Wed Jun 10, 2015 6:39 am    Post subject: Tilt Reply with quote
As I understand it, you have only one hot cyl. #6 . If you tilt the bottom of the carb to the left all three cylinders should run cooler, 2,4 and 6. If 2 and 4 are good, you may have another issue with #6. Maybe an induction leak or???
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of BobbyPaulk(at)comcast.net
Sent: Wednesday, June 10, 2015 6:43 AM
To: Server, JabiruEngine-List Digest
Subject: Tilt
List
bobby
ist">http://www.matronics.com/Navigator?JabiruEngine-List
ics.com
.matronics.com/contribution
www.avast.com [quote][b]
matronics(at)rtist.nl
PostPosted: Wed Jun 10, 2015 7:18 am    Post subject: Tilt Reply with quote
There must be a typo there. I think where it now reads "The left side will be leaner", it should have read "The right side will be leaner".
This document came from Pete Krotje (USJabiru) who definitely knows what he's talking about. He wrote a shorter version which does explain it properly. Must be a slip of the pen.
Rob
On 6/10/2015 3:43 PM, BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net) wrote:
[quote] List
bobby
