Temps
BobbyPaulk(at)comcast.net
PostPosted: Sat Jun 13, 2015 11:28 am    Post subject: Temps Reply with quote
Just got another flight in and everything is looking good except the CHT's.
I tilted the carb bottom toward the hot #6 and it came down to 1255 - #5 went up a little to 1326.
CHT for #6 was 332 while #5 was 312. No 2 cylinder head temp was 333. Power was at 2550 rpm and 20" MP.
If I leave the throttle at 2800 the EGT and CHT all go up. I'm already running a 260 main jet with 290 needle jet.
Ground temp was 85 degrees. I can not seem to get the CHT's below 300.
Any ideas?
Bobby ( age 77 )
Zodiac 601 XL "B"
Jabiru 3300 S/N  1141
Sensenich 64" x 51" Prop
Bing Carb 260 Main & 290 Needle Jet
Status - Flying 238 hrs.
