GSC inflight adjustable prop bearing failure
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List
paqs345(at)gmail.com
PostPosted: Mon Jul 27, 2015 6:40 am    Post subject: GSC inflight adjustable prop bearing failure Reply with quote
Hi Group,
I have a GSC inflight adjustable prop and had the bearing fail. Those
of you who have had that happen know what I’m talking about. I
continued flying it with the prop pitch fixed. How much trouble is it
to replace the bearing? Can someone share the experience?
Sonja
- The Matronics Pulsar-List Email Forum -
http://www.matronics.com/Navigator?Pulsar-List
mortweaver
PostPosted: Mon Jul 27, 2015 9:07 am    Post subject: GSC inflight adjustable prop bearing failure Reply with quote
Dave Weaver
rickyd54(at)gmail.com
PostPosted: Mon Jul 27, 2015 2:18 pm    Post subject: GSC inflight adjustable prop bearing failure Reply with quote
Sonja,
The only real bearing fix is to use a true thrust bearing. I will try to find the photos I made of the modified push rod and bearing cup. It is actually very easy to do. I have hundreds of hours on the same bearing. Use a INA DL12 bearing.
Barry, did I send any pics to you that you can send to Sonja?
Rick
On Jul 27, 2015, at 9:38 AM, Sonja Englert <paqs345(at)gmail.com> wrote:
Hi Group,
Sonja
PostPosted: Tue Jul 28, 2015 5:20 am    Post subject: GSC inflight adjustable prop bearing failure Reply with quote
I have the newer version of the prop with the dual bearings. They
lasted for a bit more than 600h. The pushrod got bent and damaged from
spinning around, so it is no longer possible to see exactly what the
design looked like. I would like to go with a proper thrust bearing,
if I can make it fit this version.
Any photos would be great, send them directly to me at
paqs345(at)gmail.com if the attachments to the group don't work.
Thanks for everyone's input.
Sonja
On 7/27/15, Rick Thomason <rickyd54(at)gmail.com> wrote:
Sonja,
a INA DL12 bearing.
Rick
> Hi Group,
> Thanks,
> Sonja
kdpalmer(at)mweb.co.za
PostPosted: Tue Jul 28, 2015 5:47 am    Post subject: GSC inflight adjustable prop bearing failure Reply with quote
Try GSC in Canada they may have push rods in stock still info(at)ultalightprops.com
Keith
Sonja
> Sonja,
> a INA DL12 bearing.
> Rick
> Sent from my iPhone
>> Hi Group,
>> Thanks,
>> Sonja
PostPosted: Wed Jul 29, 2015 3:35 am    Post subject: GSC inflight adjustable prop bearing failure Reply with quote
All,
The push rods are actually easy to make using the old one as a guide. Buy some aluminum rod stock from Home Depot, cut to length, slot one end, and then turn down one end to fit inside the bearing race. Actually if you use the DL12 thrust bearing I added a brass bushing behind the turned down section to provide a little additional contact with the rear bearing race.
Rick
Keith
> Sonja
>> Sonja,
>> a INA DL12 bearing.
>> Rick
>> Sent from my iPhone
>>> Hi Group,
>>> Thanks,
>>> Sonja
PostPosted: Wed Jul 29, 2015 6:43 am    Post subject: GSC inflight adjustable prop bearing failure Reply with quote
I have now removed my prop, the bearings are all but gone and the tip
of the rod was sheared off. With the dual bearing design, it is going
to be more difficult to make an adapter for a different bearing and a
new rod.
Sonja
On 7/29/15, Rick Thomason <rickyd54(at)gmail.com> wrote:
All,
Rick
> Keith
>> Sonja
>>> Sonja,
>>> Use
>>> a INA DL12 bearing.
>>> Rick
>>> Sent from my iPhone
>>>> Hi Group,
>>>> Thanks,
>>>> Sonja
PostPosted: Wed Jul 29, 2015 7:22 am    Post subject: GSC inflight adjustable prop bearing failure Reply with quote
Try the agents for a shaft and 2 sets of bearings ,be safe and replace 300 to 400 hrs
Keith
PS for interest https://www.motionindustries.com/productDetail.jsp?sku=03721939
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List All times are GMT - 8 Hours
